Hi all,
I wanna to know that Is there any program that can scan any program options then give me its registry?
i.e. if you have WMP 11 you can use such a program so that you can get its options in form of .reg file so that i can use this .reg file to control my program when i'm going to make unattended windows installation.
Hope that it is clear.
Thanks in advance
1st thanks for your reply
Install watch is a great program but...
lets say that you have WMP 11 and select option to view video in 100% Zoom i wanna the program that can tell me which registry value(s) changed. I know that there is a program called regmon that can do this job but this program require that you must make change to every option and watch what change and it will be so difficult specially if you have big program like Office or what else. So,i'm looking for program that do scan automatically without need me to watch it and try each option and its corresponding registry.
That is all
Thanks in advance and hope that it is clear now
