Posted February 15, 20196 yr The HR Associate forgot the password of employee contact spreadsheet and she ran out of luck for guessing out the password. She says the password is simple. Possible to brute-force it? It is Excel 2010
February 16, 20196 yr Hi locksnail, have you tried these steps? https://www.passfab.com/excel/forgot-excel-2010-password.html Regards, Nik
February 19, 20196 yr Author Thanks for the advice, @NIM Currently running the program and it still not finding the password
February 21, 20196 yr I had the same problem with my computer (2007 Excel).But it doesn't matter,since Excel password can be cracked. With the help of it: https://www.iseepassword.com/open-a-password-protected-excel-file.html Edited February 25, 20196 yr by Kisseasy
February 25, 20196 yr Don't run the program... Excel files (xlsx) is actually a zip archive. Simply extract the file and edit out the password. Depending on how you've encrypted it and if you are not using Encrypt with Password, then it should be all fine. If you still can't crack the password, sent it to me and I might give it a go (only if there is no sensitive info and you don't mind). Regards, SnowBall
Please sign in to comment
Sign In Now
