September 10, 200718 yr I found this nice tutorial and thought I might share it with you :icon_cool: Vishal Gupta Tutorial Edited December 9, 200717 yr by JurgenDoe
September 10, 200718 yr This sounds like a cool tweak but tell me something... Can you view icons on desktop by detail, thumbnails etc?Does the tweak enable that feature?
September 10, 200718 yr Author This sounds like a cool tweak but tell me something... Can you view icons on desktop by detail, thumbnails etc?Does the tweak enable that feature?I don't have any icons on my desktop but I can put some there and try it out :icon_rolleyes:Yup Rick it does shows everything like you want. I just added some icons to the desktop and voila it shows details etc. Edited September 10, 200718 yr by JurgenDoe
September 21, 200718 yr Thanks for this, I was looking for this for a while It IS cool and weird, more weird than cool. I dont like the way other views get displayed with no transparency but I guess it wasnt an option for a reason...I was wondering if anyone else experienced this, I couldnt use the 'views' button through any window after I applied this. ('save as' dialogs, explorer windows etc). The button is there but to see the menu it must be done through the view menu on the toolbar or rightclick.what is the number "28674" about? I dont understand how those numbers work..would it make more sense in a hex editor like PE explorer?
