September 13, 200619 yr Windows Post-Install Wizard (WPI for short) is a hypertext application designed for giving users choice. While Windows XP offers many ways of customizing the setup process out of the box, its major drawback is the lack of being able to select which applications an end user may install. In the past, end users and administrators needed to either download the files manually, or create overly complex scripts that could only be used once. WPI allows you to create one image, which can then be custom configured, and optionally, automated, so that end users can install any applications that have been configured into WPI.MAJOR NOTE!!!You must edit your config.js file and add in the missing slash marks \ because WPI no longer adds them in after using variables.Highlights:WPI ChangeLog. Modifications by Mark Ritter (mritter)===============================================================================* Quotes are now put around the command paths so spaces in the path will betaken care of.* Created a new "built-in" manual. Only 50% done.* Options -> Miscellaneous tab eliminated. Log gadgets moved to Tools tab. Use Multi Defaults checkbox moved to Installer tab. Show Extra Buttons checkbox removed.* WPI now can detect if it was started from a CD/DVD or a harddrive. Ifstarted from hdd then the extra buttons (Options, Config,....) are shown. Ifstarted from CD/DVD then they are automatically hidden. No more forgetting toturn it off when burn a UACD.* Added two new commands for Config wizard: RegKeyExists() and RegKeyValue() foruse in Cond and GCond statements.RegKeyExists("HKEY_CURRENT_USER\Software\WPI\Theme") returns true or false.RegKeyValue("HKEY_CURRENT_USER\Software\WPI\Theme")=="Glossy"* Removed all code for Media Player in WPI main window. It is still availablein the install window.* Added an icon in Config wizard to access Universal Silent Switch Finder toeasily find the switches. Arguments are not allowed, just the plain path.Sadicq totally re-wrote USSF, gave it an interface, and incorporated it withWPI so can send the switches directly to the command line.PEiD is no longer needed. Four new images in the themes folders:USSF_Out.jpg, USSF_Over.jpg, USSF_Down.jpg, USSF_Disabled.jpgNOTE: WPI and your archives folder must on the same partition!!!* WPI used to add the \ (backslash) to system variables, it now does not tobe more like native Windows environment.* A list of the global variables is now saved in the log file.* There are some extra sound files in Audio -> Beeps folder. Copy one toyour theme folder and rename to TimerSound.wav* Added to Options -> Installer: 'Start beep at t-minus seconds'To customize when to start count-down beep. Set to 0 to not play sound.* Added a check box in Options -> Installer:'If grayed condition is true, disable the check box'* Fixed a bug dealing with grayed condition not setting the text colorcorrectly.* Added %sleep% to make WPI pause for x seconds. Put it on a command line:%sleep% 10For a 10 second delay. The command window can't be hidden at this time.* Added %reboot% to force a reboot at anytime. Put it on a command line.%reboot% Reboot immediately%reboot% 10 Reboot after 10 seconds%reboot% 15 -c "A message why" Reboot after 15 seconds and show a message* Michael Mims (Zorphnog) updated the installer to allow for a reboot duringthe installation process. This will allow for drivers to be installed or usersettings to be changed, reboot, install the rest of your software.* Sadicq fixed a bug in the Config wizard dealing with adding a new categoryit would duplicate what was already there.* InstallProgBar.png and TimerProgBar.png are now two seperate entries in thewpi.css and installer.css files. Can have two different images.* Updated the Options tabs to a better version that is AJAX based. Thischanged the theme files yet again.* Fixed a bug dealing with forced items not being re-checked when hit Exit andForce Install is checked. Caused by Zorphnoq's update below (not his fault).* The tool tip style is now theme independant. A new file is saved in the theme folder, wpi_style.js, for each theme's tips. Your current settings willbe saved the first time you go in to the Options wizard.* David Di Certo wrote code to get the operating system's language TLA for usein the installer as a variable %oslang%. It can be used like this in acommand line:WindowsXP-KB918899-x86-%oslang%.exe* Fixed a bug dealing with the audio player in the Classic theme.* Eliminated generate.js by moving the code to core.js and installer.js. Alsocleaned up some of the function calls that were repetitive.* The gcond[] statement in config.js is now only saved if changed from thedefault: FileExists('%programfiles%\').* Fixed another bug in the timer if set to 0 in command line args or inuser options.* Fixed a bug in the count down timer.===============================================================================DownloadDownload Here!Notes and ExtrasSuggested disk folder layout:With the above folder layout all your config entries should read like:%wpipath%\Install\Blah.exeI have seperated the tools out from the main archive. You can download the tools here:Tools archive.Contents of the tools archive:cmdowUniversal Silent Switch FinderPEiDWPI Config ListerCDSwitchautorun.inf <-- Updated and fixedwpi.ico New icon thanks to WolfX2TaskKillS.exe from sadicqHere is a quick start package that will set your windows disk up to use WPI with runonceex all you need is to place this %oem% folder at the root of your windows disk. You MUST have the line "OemPreinstall=Yes" in your winnt.sif file if you want to have the MCE theme if you dont feel the need the cmdlines.txt will still run WPI for you even without a winnt.sif file.%OEM% Folder.Contents of the %OEM% archive:Media Center Style XP Theme (NO uxtheme.dll hack needed!)cmdlines.txtregentry to set MCE theme for runonceex window.runonceex.cmd1194 .png images for your pleasue to use in your tooltips or whatever!PNG Collection.How to make a winnt.sif file.Here is a small tutorial on how to add an app to WPI!Ok this is a sample (Very simple) configuration for Windows Defender Beta 2 This assumes you have all of the WPI files either in the WPI folder at the root of your Windows cd or all of the WPI folders (Common, Graphics, WPIScripts, Tools, Install and Themes) and the file WPI.hta at the root of your cd.Remember this is just the most basic and required entries for a program!#1 Place the desired app in the install folder. (In this case WindowsDefender.msi)#2 Run WPI.hta and choose
September 13, 200619 yr Author HEY [ codebox ] does not work on this forum!n1k please consider adding in [ codebox ] functionality!
September 14, 200619 yr n1k please consider adding in [ codebox ] functionality!Is this what you ment Kels or something else?If it's something else I'll check it out when I return from vacation..
September 22, 200619 yr Author Nope but close [ Codebox ] gives you a scrollable code section on really loooong sections...I've fixed it, I've just put the line "" into a next row and it worked..
