Use large icons
Don't matter !
You can test it on each file !
It seems that it reduces its size from 48x48 to 32x32 :(
Edited by PJP2007
probably just a glitch in the way you set up your disply settings. Between a hardware driver (like nVidia control panel), the 'use large icons' radio box in the start menu property sheet and the actual icon size settings in desktop proteties>appearance>advanced.
Of course this could be controlled by a buggy theme you installed. You could always hack the properties sheet dialog and extend that portion of view? Im havin g issues with dialog text being cut off in buttons and my buttons are big and the text small. I think I'll retire from modding
You can prolly fix this by editing the icons in shell32.dll (edit/remove the 16 bit icons from the .ico file)
I just see 16,256,32bit :(
Can you explain more ?
I also tested it with luna :(
Is there anyway for hacking the dialog ?
I see some properties in it:
