September 30, 200718 yr Here is a way to convert Google or any Gadget and use it on your Vista's SideBar. I have tried it successfully with Widgets from widgetbox too. You can transform almost any gadget into one that can live on the Windows Vista sidebar or your Desktop.Download & Install Amnesty Generator. Then, choose a Web gadget you'd like to turn into a Vista gadget, click a few buttons to display the gadget's underlying HTML code. Copy and paste that code into Amnesty Generator, change a few settings, such as the gadget's name or size, if you wish, and tell Amnesty Generator to turn it into a Windows Vista gadget. The gadget will appear in the Windows Vista Gadget Gallery. From there you can move it to the Sidebar or even your Desktop.
