hi all
i add more than 12 addons in my xp cd (unattended)
but when i test it in (virtual pc 2007)
when the setup finished
i never find any addon installed :crying_anim02: :crying_anim02: :crying_anim02:
just i find the progs (in svcpack) (just 5 progs) installed :confused02:
HElp me pleease
what's the problem ? :crying_anim02:
why just SVCPACK folder installed ?
i integrate all addons via RVM_Integrator !
so it was integrated 100%
pllllz hep !
Edited by N1K
hi all
HElp me pleease
pllllz hep !
Sounds like you have a bad INF addon, you have to track it down
Post a list of them
just 4 addons working :crying_anim02:
tell me what i can do :please:pleaaase
(all addons downloaded from here (www.wincert.net)
i think that the problem is the all addons are english and i integrated them with a french version !!!! 0r not ??? :g:
Edited by Arfaoui FirAs
Well it's not simple solution but you'll have to group,split in half,use one half and test it would it work. if it works add other two addons from other group...until you locate false addon. Hope this helps... Good luck..
Did you check the MD5 to make sure the download was correct? Those files may have been corrupted during the DL.
never
downloaded all 100%
i checked the MD5 Hach
then when i integrated them 100% also
so where is the problem ?
then just all progs in SVCPACK WAS INSTALLED
:crying_anim02:
and if u want to try 0r check it i uploaded them from this link
OK, all these files I don't believe were downloaded from here.
I have downloaded several of them:
BulbaCPL2006.6.0.19 and Defraggler CPL1.0.0.31%5BAddon%5D.7z has errors in the inf and ini.
Question about HD Tune v2.54.7z and HDD Thermometer v1.3 both of those are mine and they have no errors but the arc. was changed from Addon_by_LUZR4Life to %5BAddon%5D, Who did this and why?????
Try to install the addons again without
Edited by LUZR4LIFE
I removed BulbaCPL2006.6.0.19 and Defraggler CPL1.0.0.31 from the cd and the addons and from the TXTSETUP.SIF and DOSNET.INF file but when i try that in vertual machine more than 60 minutes :crying_anim02: :crying_anim02:
JUST SEE THE PICTURES THEN U'LL UNDERSTAND ME
Ask Me For The Files Who Deteled
Trying It In Vertual PC 2007 (39mn)
And FINALLY NO ADDONS INSTALLED JUST THE LAST 4
NO CHANGING NOTHING WAS CHANGED
WHAT I DOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO :crying_anim02: :crying_anim02:
OK what you need to do is test them like 4 at a time using vmware untill you find the group that fails you.
So integrate the 4 that work and 4 others (Use some kinda sorting) ans then test.
I know its a pain in the ass but hey what else can you do?
Hey Kel, I sent them a link for your ubber pack so they could use FCGBA to test them also.
