Uninstall question?
Ok....
I'm working on a addon that saves its settings and such in
C:\Documents and Settings\Reapers\Application Data\Program Name\
Question I have is when creating a uninstallable addon, how would I
make the addon uninstall that particular part.....
Because not everyone has C:\ as their main drive, and of course there username
would be different also.......
Any help would be appreciated...
OK pretty easy, in your [uninstall] section in the DelFiles directive you add a new section name (anything) example
[Uninstall]
DelFiles=Example.Other.Sections,New.Section;<-Add it here
Now create it and under the [New.Section] you add a list of those files you want deleted (the one that the program creates)
[New.Section]
Filename1.ini
Filename2.bak
etc...
Now you have to add the New.Section=LDID(,SubDir) to [DestinationDirs] so the INF will know where the files are, so go so look for the LDID of the %UserProfile%\Application Data
Here is the LDID (number) for that folder
16410 %userprofile%\Application Data
So it will go like this
[DestinationDirs]
Example.Section=16422,"Program Name"
New.Section =16410,"Program Name";<-This is the DelFiles destination dir
The folder where all the old filenames exist must be defined in a DestinationDirs section as shown in the
above example.
Post your INF when you think you are done maybe we can have a look at it
Ok.....
This brings up another question....
The program creates the config file in the directory like I said before.....
BUT.....
The file is named like this....
Reapers.cfg
So it names the config file after the username that is being used.....
So how would you allow for this....?
OK in your uninstall section try something like this (this will delete all the files not matter what they are in a directory)
[Uninstall]
RunPostSetupCommands=RunPostSetup.SectionName ;<- You can name this whatever you want
[RunPostSetup.SectionName]
RUNDLL32 advpack.dll,DelNodeRunDLL32 %16410%\%Program Name%,8
You can change the flag (8) to do different things
1  // delete the directory only if it's empty
2 // don't delete any sub-dirs; delete only the files
4 // don't delete the dir itself
8 // delete UNC [network] paths ;This deletes both the files, sub dirs and the folder itself
