March 15, 200818 yr not exactly sure where to put this.. i'm not affiliated with this program, but i've used this program in the past and its pretty simple. while it may not be as advanced as some other programs, i was happy with the results and i found it does the job quite well. link One thing to note, make sure you don't install the search toolbar.From the fairuse website:2.8If you get an "adware" alert while installing, this is because the installer contains a search toolbar, which installation is optional.I set up this partnership in order to distribute the full edition for free, though this is still experimental.I also would like to add that it is the FairUse installer that decides to install the toolbar or not, based on a checkbox. This means that nothing unwanted can be installed on a system without the end user's explicit consent.
March 15, 200818 yr Author hmm maybe this would be better in the Software Field forum.. damn i gotta stop posting in the middle of the night Edited March 15, 200818 yr by ccl0
