how do i create an .exe for this?
ok for starters this is about the inkball game from tablet edition fixed for xp.
it works great and opens everytime it's clicked but does not show the cursor,but i found a fix.
after opening the game and pressing alt on your keyboard the cursor shows.
what i'm looking for is and alternitive .exe that will 1. open the game and 2. will auto apply the alt key.
but i want the .exe to use the inkball icon.
is there away of doing this?
as i would want the new .exe to reside in the same folder with the game.
thanks in advance, jimmy
How about a share and instructions on how to make it work
would love to but i haven't a clue.lol
after downloading a ton of different inkball versions that claim to work this is the only one so far that seems to.
i forget which blog i got this from but some user posted it saying it worked on his xp home.
here is a megaupload link to the fixed inkball game. ( http://www.megaupload.com/?d=3KHP37WD )
after you open the game just hit the keyboad alt key to show the cursor.
p.s. its from the xp tablet edition but i changed the icon to the vista one.
HMm, let me check the file.
Edit: Hey i cant download from megauload. Can you upload somewhere else please? Rapid is ok for me.
Edited by MrNxDmX
