Weird looking devices
I do have some weird looking non P&P devices in my Device Manager.
Anyone got a clue what the hell they are?
I also have there other suspicious drivers that does not support P&P, and their names are:
ATICDSDr
atidgllk
Beep - used, could this be removed for good somehow?
BOPOMAV
c34nb4c5
DirectX DLL register
e259q4c6
Fs_Rec
rvbedit (I killed this one already)
SSDefrag (I killed this one already)
NetGroup Packet Filter Driver
Parallel - used, could this be removed for good somehow?
YQZBNWOGRK (I killed this one already)
Can I remove/uninstall few of them?
ATICDSDr - That should be ATI Control Panel (don't remove it)
ATIDGLLK.SYS is related to ATI Diagnostics Hardware Abstraction Sys (no need to remove it)
Beep - The Blocks Extensible Exchange Protocol (not sure about this)
I just saw that you've asked this question on various forums ;)
Of course I rather ask on more places and then come back with more info! :P
Well, fist at all, to see all these devices, you have to use the registry tweak:
REGEDIT4
;show all the devices in the hardware table
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment]
"DEVMGR_SHOW_NONPRESENT_DEVICES"=dword:00000001
And then reboot + choose in the menu again show all devices. Then you can see these.
And true, I had a mallware infection when I was running IE. Not anymore, but some stuff can remain there.
ATICDSDr - removed, no ill effects
atidgllk - removed, no ill effects (I do overclock, but I have nVidia card (ATI mobo chipset tough) and mobo I overclock in bios)
Beep - used, could this be removed for good somehow? Is not that the "beep" speaker anyway? We see if it come back :D
BOPOMAV - removed, no ill effects
c34nb4c5 - removed, no ill effects (probably related to PunkBuster)
e259q4c6 - removed, no ill effects (probably related to PunkBuster)
Fs_Rec - removed, but it keep comming back (should be File System recognizer)
NetGroup Packet Filter Driver - part of WinPcap - installed for Etheral sniffer, removed
Parallel - removed, but it keep comming back (parallel port disabled in bios)
YQZBNWOGRK - removed, no ill effects
