MiniBin 1.5.0.0
Recycle Bin icon for your system tray menuThe MiniBin application was designed to be a trashbin for your systray.
It may come handy when you're hiding the trashbin from your desktop or if you're using a replacement shell that provides a system tray but no useable trashbin.
With a mouse click you will be able to empty your Recycle Bin. A different icon will be showed if you have any files that need to be erased from Recycle Bin.
What's New in This Release:
