[Help] Blue Copy, Move and Delete Dialog
Hi.
Anybody know how can I convert those green animations of copy, move and delete animations to blue for XP, just like the ones on Aero Diamond from Mr. R0UNDER (Link).
I tried to reshack them in the Aero Diamond theme but with no luck, I guess they will appear only when using Vista, wich I don't like, hehe.
I just would like to match my whole blue desktop.
Thanks.
It will help for sure, thank you for the idea.
Vista no longer use AVI files, its a different deal
Yep, now I can see that, hehe, thanks.
I managed to extract BMPs from the AVIs, now I have to edit each one seems like, and then convert those BMPs to AVI again, and that's where I have problems.
If there's any recommendation about what kind of software can I use, let me know.
Thanks.
