May 3, 200818 yr I want integrate SP3 in Win xp2 along with following addons:Software to be used Ryan integrator and nlite for tweaks.1. .Net framework AIO(Ryan or Rougspear which one to use?)2. Kel `s Runtimes(Does this addon contains all runtimes including VC++ 2005 & 2008 and Java Virtual Machine)3. WMP 11 along with updates.4. Kel's CPL All-in-One v8.2.15. Which is best vista theme along with proper icon packs.6. Convert to Media centre edition by using addon this forum.want to know about stability with sp3.Do switchless (.exe) installers are integrated by Ryan integrator?Suggest me suitable tips and procedure for integration process. Edited May 3, 200818 yr by Aceoneo
May 5, 200818 yr 1 --> http://www.ryanvm.net/forum/viewtopic.php?t=56572 --> yes but NO Java There is a Java runtime enviroment 6 update 6 in this forum and on ryans forum made by me. (Totally silent!) http://www.ryanvm.net/forum/viewtopic.php?t=38503 --> You need WMP11 Slipstreamer for that http://web.clicknet.ro/boooggy/4 --> Yay me!5 --> Dunno6 --> no clue...Yes silent .exe files are added just like they are.
May 5, 200818 yr 1. .Net framework AIO(Ryan or Rougspear which one to use?) - its a matter of preference 2. Kel `s Runtimes(Does this addon contains all runtimes including VC++ 2005 & 2008 and Java Virtual Machine) - you could pm him and ask or ask in his thread. edit: looks like he already answered that part5. Which is best vista theme along with proper icon packs. - its a matter of preference 6. Convert to Media centre edition by using addon this forum.want to know about stability with sp3. - that pretty vague question. if you just want to know if it works with sp3, ask/pm the creator of the addon Do switchless (.exe) installers are integrated by Ryan integrator? - its very simple to see if they do. open rvm and browse to one and see if it gets accepted. if it doesnt it wont show up to be selectedSuggest me suitable tips and procedure for integration process. - kind of a vague question. Edited May 5, 200818 yr by ccl0
