NetMeeting
Run: Start/Run/conf.exe
Remove: Start/Run/RunDll32 advpack.dll,LaunchINFSection C:\WINDOWS\inf\msnetmtg.inf,NetMtg.Remove
Reinstall: To reinstall, open the Windows\Inf folder (this is a hidden folder, so you may need to adjust your Folder Options
to show hidden files and folders. Or you can click Start, Run and enter %systemroot%\Inf). Locate the
msnetmtg.inf file in the Inf folder. Right click and select Install. Have your XP CD handy.
Tip: Clear Netmeeting Call History - Start/Run/Regedit
HKEY_CURRENT_USER\Software\Microsoft\Conferencing\UI\CallMRU.
Open your registry and delete the key. Restart Netmeeting for the change to take effect.
