Desktop icons Bigger
Like you would do manual
Right-click the desktop and choose "Properties" Select the "Appearance" tab then click the "Effects" button.
Then you can torn it on (Use large icons)
I believe it is 64
I need an addon for nlite - silent install
It looks better
well nlite already has an option to change their size. i know you can change it to 32x32 and 48x48, maybe different sizes too (i forget)
but if this has to do with nlite i'd suggest you ask in their forum, if you havent already
The bigger size is 48 and I seen some where in nlite but I can not find it now
Probably a older version of nlite
Can you tell me where in nlite or tack a picture
Thanks
You can use this software find this post
POST
Usually if you try change size of icons you need use sizes from 1 up to 72, because standart tools of Windows do not allow to set up size of icon to more than 72 px. IconSize will provide feature to set up icon size up to 256 px.
Tested only under WindowsXP, not needed for WindowsVista
POST
Thanks
All You told me what I needed
I got it
Edited by Iury
