In Vista when you install updates you can postpone a restart for upto four hours. Is there a similar prog for XP and if there is can it be made into and addon?
TIA
Running the hotfix with "/norestart" command does the job offline, but your asking for windows update installations. I have no idea for that, sorry.
Thanks for the response. It's for when Windows updates automatically (little yellow shield thing in the systray) and then pops up a window asking to restart or postpone. In Vista you can postpone for up to 4 hours. Not a big problem just a small annoyance really.
Edit : Just found this
http://thebackroomtech.wordpress.com/2007/10/12/how-to-delay-the-windows-automatic-updates-reboot-nag-screen-and-the-automatic-reboot-after-applying-updates/
Describes a reg file to delay restart for 24 hours.
Also this.
http://www.ejabs.com/blog/2007/05/how-to-disable-the-windows-xp-automatic-updates-restart-nag-screen/
How can I incorporate this in nLite or similar?
Edited by bigb
Ok, nice find. You can add these registry entries in one of your inf files:
[REGEntries.AddReg]
HKLM,"SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU","RebootRelaunchTimeoutEnabled",0x10001,01,00,00,00
HKLM,"SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU","RebootRelaunchTimeout",0x10001,a0,05,00,00
HKLM,"SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU","NoAutoRebootWithLoggedOnUsers",0x10001,01,00,00,00
Then the trick would work (dunno if it does what you want, though)
Edited by MrNxDmX
