vista viewer to xp
hi all
u know when u put ur mouse on a jpeg in vista and u see a little windows whit the image can i have that in windows xp?? if yes could some body tell me how
thanks u
P.S:sorry for my bad english :P
Edited by bud1weizer
:o i think my Vista even doesnt show thumbnail on tooltip by default (only PhotoGallery does). Or do i miss something? :g: But thx, its fixed even better now by using your suggestion (QT bar). also compatible with Vista :P Thx
:PEDIT: If you want "ported" Vista Explorer (and Search) preview pane for Xp (Vista File Viewer), maybe this is your way to go :
http://www.wincert.net/forum/index.php?showtopic=4124
Edited by AMIRZ
