December 19, 200817 yr Visual Subst - virtual drives in effectWebsiteMainly got to know from N1KVisual Subst is a small tool that allows you to associate the most accessed directories with virtual drives. It uses the same API similar to the console 'subst' utility, but makes it easier to create and remove virtual drives in a GUI way.VSubst106.exeSize: 141KBMD5:C351B7B9A584DFF6FAF7AEF95749F91CCreate a shortcut in taskbarInstalled to: Program files\Visual SubstUninstallable: Yes
