1st BOOT
I was wondering if there is a command line that can be added in nLite or RVM so once the install of an OS is finished that all desktop icons would be deleted? If so, whats the command and where should it be added?
Thanks!
If you use WPI it can do this, just dl the tools folder
Without WPI, is there another way? Thanks for the fast reply Rick! Sorry for the n00b Q's but getting a response from the pros here is faster and more accurate than searching google..etc.
