hi
i have try to make an addon of realpalyer but when i extract the setup then i could not found any exe to start setup.
please help me ? :help:
Could you provide us more info? like what did you extract exactly using which program? And screen shot of files that are extracted? That would be a good start.
Yes that is link to online installer. So when you run it it stores/downloads needed files from internet before it installs on live system.
The exe file you need is stored at Documents and settings\User name\Local settings\temp\rninst~1
You should find RealPlayer11GOLD.exe there. Then you can play. :)
i have RealPlayer11GOLD.exe i want to make it silent please help me
I've visited the link you've posted and downloaded the "RealPlayer11GOLD.exe", but as @Gorki said, it's an online installer (you need to be connected on internet to download files you need for instalation).
The real size (full) is ~13MB, so search the network and you'll find it.
I hope I helped. :type:
