January 31, 200917 yr Is it possible to add the registration serial number to a silent install application ?Thanks Natty.
February 1, 200917 yr Author yes it is.For MOST apps.Which one are you tryinConvert x to DVD . ( Please give me an idea how this is done .) Thanks .
February 1, 200917 yr Search your registry for that name or the companies name.I believe that the app you want keeps the reg info in the registry...Then can the reg file after the installation of the app.Windows Registry Editor Version 5.00[HKEY_CURRENT_USER\Software\VSO\ConvertXToDVD\3.0]"LicenseKey"="Serial-will-be-here"This is the key you want to use...
February 1, 200917 yr Author I used SFX Maker to make my Silent Switch App and that work very well.How would i apply the serial code using this program ? or do i need to use another program to make this happen.Thanks again for your help.natty .
