Hi.
I am interested in finding out what this hive file is for and what it does, i have searched on google but came up with nothing.
If anyone has any info on this file or a link please i would be very greatful.
Many Thanks
Worf
Edited by Worf
You will find 5 HIVE*.INF files uncompressed in your i386 folder, they are added right after textmode setup just before it reboots into gui part of the setup and are basically the windows registry "hive".
They are given names depending on what part of the registry there for example:
HIVESYS.INF = HKLM\SYSTEM\*
HIVESFT.INF = HKLM\SOFTWARE\*
HIVECLS.INF = HKLM\SOFTWARE\Classes\*
You get the idea
Hi Rickendo64
Thank you for your reply. I know about the the other Hive files, it's just the HiveUSD file that i'm not sure about.
Regards
Worf
  • 3 months later...
I just tried installing xp on a laptop of a firends
they did know what was wrong with it.
most of the files couldnt not copy
at the very end when i thought widows would still load
I got this error
Line 0 of hive.inf is coruupted
is this fixable ?
or should I just get a new Drive for it? or what
any advice would be greatly appreciated
thank you
Rose 13
