I need help resetting password in Vista
My sister in-law has forgotten her password. Is there a way to reset it without using a rescue CD? If not, what rescue CD do you recommend?
Thanks
Her account is the Admin Account so it can't be changed through Safe Mode
Edited by LUZR4LIFE
Thanks
is that the only accont user you have
can you enter any account that have complete access (administer)
then just go into user account then manage other account
then remove password
if not
try to log into safe mode and user administer should appear
then do the same thing
or try this
http://www.password-changer.com/download.htm
edit :
LoL now i saw your edit
go to this site
http://home.eunet.no/~pnordahl/ntpasswd/
boot disk then download and follow the instruction
Edited by DaRk MaDnEsS
Thanks DaRk MaDdNeSs, I will check that out
Hope it works
LoL i just wanted to comment on the way you typed my name :P
DaRk MaDdNeSs
it's only one d :rolleyes:
it's nothin but don't know why i'm LoL right now that hard
Hope it works
LMAO. I just noticed that. It's hard typing your name. I should just call you D. LOL
  • 2 years later...
Reset With a Reset Disk
* 1 Recognize the error message. When you type the wrong password, you receive a message that says "Your password or user name is incorrect."
* 2 Click "OK."
* 3 Click "Reset Password."
* 4 Complete the instructions that follow. Windows Vista prompts you through the password resetting process.
Reset With an Administrator Account
* 1 Log in to your administrator account.
* 2 Click the "Start" button to open your Local Users and Groups.
* 3 Type "lusrmgr.msc" into the search box. Click "Enter."
* 4 Type the administrator password and confirmation, if prompted to do so.
* 5 Double click on "Local Users and Groups."
* 6 Click on "Users."
* 7 Locate the account for the password you need to reset. Right-click on the account and select "Set Password."
* 8 Type your new password.
* 9 Retype your new Windows Vista password to confirm it.
