(SOLVED)How to change filetype association?
hi
:albert: after seeing some .reg files in my registry i made some thing like this :rolleyes:
[HKEY_CLASSES_ROOT\.abc]
@="Mplayer"
[HKEY_CLASSES_ROOT\Mplayer]
@="abcfile type"
[HKEY_CLASSES_ROOT\Mplayer\shell]
[HKEY_CLASSES_ROOT\Mplayer\shell\open]
[HKEY_CLASSES_ROOT\Mplayer\shell\open\command]
@="\"C:\\Program Files\\Mplayer\\MPlayer.exe\""
with that i was able to open my .abc with mplayer by default :dancing:
:blush: my questions are:
1.Is it right or need to change the code
2.what if i need to associate the app with .dat,.vob,.mp4 .....etc create a reg file for all the types
Edited by q123
:albert:
:wub_anim: thanx alot for your support
hmmm to open that file.dat in that Mplayer the working commmand is
@="\"%ProgramFiles%\\Mplayer\\MPlayer.exe\""%1\""
else just player is opened nothing happens
Edited by q123
