hello peoples,
i have a question for create a addon, but this addon i want to create entry of unistall in add/remove component funcion,( not in add/remove programs, i don´t like this ).
sorry if they do not understand well, but I took time without speaking English, i always speak in spanish.
help explain that I put in my entries, to do this
thanks all.
Edited by zookey
well zookey
i didn't understand you well
so what exactly do you want ?
do you want to make an uninstaller for a program using inf ?
or do you want to make an Uninstaller Reg for a program ?
well it was a long way
but i will try to remember how i used to do it
first in entires you need to remove the "hide"
it would be beside the inf
then in the "Optional Components"
make a new entry called
Uninstall=
and a section name
and make that section and add the uninstall parts
First you have to learn how to make regular .INF addons to install your program, then you move onto tackle .INF uninstall, then you move onto Optional Components uninstall, not wise to skip steps
When I create a addon I need to add the corresponding registry entries, but how do I find all entries in a program? Do you make one by one? there any program that does this? :questionmark:
Edited by zookey
When I create a addon I need to add the corresponding registry entries, but how do I find all entries in a program? Do you make one by one? Is there any use for it? :questionmark:
before you install a program you need to use Install Watch or RegShot
to know the changed registry for your program
and yeah some programs needs the registry to work
If you want a Spanish version of WLM that does the same, look here.
well he wanted to know how to make the add/remove component (Optional Components)
and also rick made the normal addon in the spanish section
He asked me to make a true wlm addon lik OnePiece that uninstalls from add/rem components...I told him its not worth the trouble, msi installer is perfectly fine
But if he, in the end, ends up learning a thing or two about making addons then I guess this would be worth it
si rick ya vi tus videos y los entiendo perfectamente, dentro de poco comenzare a probar resultados de addon que aga aver si cojo un poco de experiencia. gracias por los videos
thank
