Vopt lets you quickly defrag and pack your disk drives to maintain optimal performance and reliability. Vopt's speed makes daily defragging both practical and desirable. Vopt also provides tools to assist you in maintaining your system, reclaiming wasted disk space, and protecting your privacy.
Vopt offers many different lanquage choices to give you the comfort of working in your own native language.
Main window map
Vopt's initial main display is a graphic map of the drive showing which clusters are fully used, partially used, and free (unused). After you do an analyze or defrag, the map shows which clusters contain normal files, fragmented files, fixed (immovable) files, excluded files, metafiles, system restore files, startup files, and the hiberfile.
When you click on the map after an analyze or defrag, Vopt displays a window which lists the files using that area. You can drag a file from the list and drop it into a new location on the drive. Be sure to right-click on the list for options -- you can even compress, uncompress, encrypt or decrypt files from this window.
Buttons
* Defrag drive - Defragments the currently selected drive.
* Analyze drive - Determines and displays what each cluster of the drive is being used for
* Cleanup - Lets you view and delete cookies, internet history, temporary files, the USN Journal, etc. Cookies you don't want deleted ("Subscriptions") can be entered so that you don't lose access to your favorite web sites when using cleanup.
Defragmenting menu
* Defrag drive (tighter packing) - Performs extra work to reduce the number of small gaps left after defragmenting. This takes more time.
* Quick defrag (VSS compatible) - Files larger than 64 MB are not defragmented, and file packing is minimal.
* Batch defrag - Defragments the multiple drives you select, and turns off the system afterward if you like.
* Defrag pagefile - Defragments the pagefile.
* Exclusions - Lets you exclude files from being moved.
* Schedule - Lets you schedule automatic defragging.
* Advanced settings - Lets you set Vopt's relative priority and other options for faster defragmenting.
Status menu
Following an Analyze or Defrag, displays important information about the drive..
Health menu
* Check disk for errors - Provides a more informative access to Window's drive checking facility.
* Drive failure prediction - Checks the drives' hardware status to ensure that they are in good working order.
* Drive performance - Provides a realistic measurement of actual drive throughput.
Tools menu
The tools menu provides several useful tools for viewing system information and enhancing performance.
Limitations
* Maximum partition size: 16 TB (terabytes) for volumes formatted with a normal 4096 byte cluster size. Larger cluster sizes will increase capacity; smaller cluster sizes will decrease capacity (e.g. 2 TB maximum for a 512 byte cluster size).
* NAS (Network Attached Storage) drives cannot be defragmented, and are not displayed in Vopt's drive list.
more info. http://www.goldenbow.com/index.html
Silent Install
link. http://rapidshare.com/files/289447365/Vopt_V9.21_silent.exe
CRC32: 045380de
MD5: fdc38d342c03bd94f194d8bdb11dfbb1
SHA-1: dd6189312b530c8595fe56f4b7541433d980c4cc
file size. 3.64 MB
nLite Addon
Sorry not guna upload the whole file any more just the file 2 make it, All that is needed is a drag & drop of the above exe, and its done.
link. http://rapidshare.com/files/289447367/nLite_Addon_Files_4_Vopt_V9.21.rar
CRC32: 13916616
MD5: bc03e0fadbd34119f95f7d46c416913b
SHA-1: 648320adb16bf37462d2486cb182d4a3813c9253
file size. 4.00KB
Edited by jamesbebby
....."Sorry not guna upload the whole file any more just the file 2 make it, All that is needed is a drag & drop of the above exe, and its done."....
yeah james...I trod the same path as you but with the switch "/S" and using WinRAR, but as also you, I could not eliminate the progress bar that appears ...
Thx james ... your method is also good!
But do you have any idea how to eliminate this progress bar?
hi, what the progress bar on the vopt installer?
cheers james
This:
but then the bar disappears and Vopt installed. I can not remove (not appear) this bar to complete silence during t13
regards
Edited by arsenalz
hi, the switch /S was a guess, i think this is as silent is it gets with switchs.
u could try using autoit 2 hide the install box, but i dont know how 2 do that i hav ask on the autoit forum 4 a other project, but hav know luck.
cheers james
well can you upload it to another upload other that rapidshare
and i will take a look at it
cheers james
Thanks james! I'll try to do this...
DaRk MaDnEsS, thanks for you too
