[Release] FileMenu Tools V5.17 [01/07/09]
FileMenu Tools allows you to customise the context menu of Windows Explorer. And it lets you:
* Add some built-in utilities that perform operations on files and
folders.
* Add customised commands which run external applications,
copy/move to a specific folder or delete specific file types.
* Configure the "Send to..." submenu.
* Enable/disable commands which are added by other applications to
the context menu.
info- http://www.lopesoft.com/en/fmtools/info.html
Silent Install
link: http://rapidshare.com/files/300007105/FileMenu_Tools_V5.17_silent.exe
CRC32: 138f679f
MD5: 59227db50d2eded42766063f52f39884
SHA-1: ec9dffb59837bcca7c3bbdd945c2e497b56a760a
file size: 3.65 MB
nLite Addon
Sorry not guna upload the whole file any more just the file 2 make it, All that is needed is a drag & drop of the above exe, and its done.
link: http://rapidshare.com/files/300007107/nLite_Addon_Files_4_FileMenu_Tools_V5.17.rar
CRC32: a3a0e1fa
MD5: afe70ee57b4fbc9ca151c6f861b4c535
SHA-1: dfde9e7ef68dad0f6a50a3ca4b67214918326384
file size: 4.00 KB
  • 1 year later...
