December 1, 200916 yr I've been trying to make cds/dvds with driverpacks installed and I wanted to integrate ie7 and wmp11 into it. But each time it stops the installation with these error messages:'An error has been encountered that prevents Setup from continuing.Setup failed to the product catalogs. This is a fatal error. The setup log files should contain more information.Press OK to view the Setup log file.'And the log file of the error is:'Error:The signature for Windows XP Professional is invalid. The error code is800b001.No signature was present in the subject.***Fatal:Setup failed to install the product catalogs. This is a fatal error. The setup log files should contain more information.'Can anyone tell me what I'm doing wrong and what is error code 800b001?What is and how do I put in the signature.And sometimes it says something like the "Normaliz" (dll?) cannot be found
December 1, 200916 yr I've been trying to make cds/dvds with driverpacks installed and I wanted to integrate ie7 and wmp11 into it. But each time it stops DriverPacks needs to be added last...try it like this:always use a clean xp source.first integrate updates and addons then DriverPacks.
December 1, 200916 yr Author Thanx a lot Fixit. Now the other problem is that there is still a folder named "D" with the extracted DriverPacks and some other loose files in the root after the install. Is there a switch to make sure that they do not show in the root folder?
