December 11, 200915 yr FeaturesChange SFX icon.Create shortcuts for current user or all users.Create environment variables.Run multiple programs one by one after extraction.Delete SFX file after extraction (Self-delete)Select overwrite mode for files.Hide extraction progress.Compress SFX stub with UPX to reduce size.Enable/disable XP Visual style.Set extraction path. Allow/deny users to change the path.Extract to temporary folder for software setups.Save/load settings.This is a tool for making Self Extracting EXE files from 7-ZIP files. This program uses the modified SFX module developed byOleg Scherbakov.This program requires .NET Framework 2.0 or above to run. Version 3.5 or 3.5 SP1 is recommended.http://teejee2008.wordpress.com/7-zip-sfx-maker/
December 12, 200915 yr Nice! I'll give this a try. I still use Vier's CreateurSFX but it hasn't been updated in a few years.Thanks for the link!
December 13, 200915 yr I use this one from http://www.isoft-online.com/ this has been working flawless for me, im not trying to ruine your topic/post. Just wanted to share this great tool from him.. Its also called SFX Maker and are very user friendly. merry chrismas to all.
