Install applications automatically
I want a solution for Windows 7 that my applications are installed automatically during the preparation of the office because I used the command but setupcommand.cmd HKCU registry keys of my programs are not listed in the registry. Have you a solution
Best regards
You can add your apps to install in your Autounattend.xml with FirstLogonCommands or do as I do call WPI with it
<FirstLogonCommands>
<SynchronousCommand wcm:action="add">
<CommandLine>cmd /q /c for %i in (C D E F G H I J K L M N O P Q R S T U V W X Y Z) do if exist %i:\wpi\wpi.exe start %i:\wpi\wpi.exe</CommandLine>
<Description>Windows Post Install Wizard</Description>
<Order>10</Order>
<RequiresUserInput>false</RequiresUserInput>
</SynchronousCommand>
</FirstLogonCommands>
There are 3 methods of integrating 3rd party applications in the installation DVD;
1. $OEM$ folder and setupcomplete.cmd file
2. Install folder and start.cmd file and putting the shortcut in startup folder.
3. WPI way.
I prefer the second method.
  • 4 weeks later...
I use the same as Rick:
        <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<CommandLine>cmd /q /c for %i in (C D E F G H I J K L M N O P Q R S T U V W X Y Z) do if exist %i:\WPI\WPI.exe start %i:\WPI\WPI.exe</CommandLine>
<Order>10</Order>
<TimeZone>W. Europe Standard Time</TimeZone>
<DisableAutoDaylightTimeSet>false</DisableAutoDaylightTimeSet>
<DoNotCleanTaskBar>true</DoNotCleanTaskBar>
<BluetoothTaskbarIconEnabled>false</BluetoothTaskbarIconEnabled>
<ShowWindowsLive>true</ShowWindowsLive>
</component>
But in VMWare WPI isnt being executed @ first login? I dont get it, tried a lot, but it wont work, might be vmware.
