April 26, 201015 yr SpeccyDescriptionAt first glance, Speccy may seem like an application for system administrators and power users.It certainly is, but Speccy can also help normal users, in everyday computing life. If you needto add more memory to your system, for example, you can check how many memory slots your computerhas and what memory's already installed. Then you can go out and buy the right type of memory toadd on or replace what you've already got. If you're going to be selling your PC, you can useSpeccy to quickly list out the components. Or, if you're buying a PC, you can use Speccy to checkthat the computer has what the label says it has. Also, Speccy comes in handy for support. Ifyou're on the phone with technical support and they want to know what video card you haveinstalled, there's no need to hunt around Windows. Speccy has all the information on oneeasy-to-understand screen.Changelog:v1.26.698 (29 Apr 2014) - Added SMART attribute real values and statuses. - Restructured SMART attributes and RAM JEDEC data into grid view. - Improved Windows 8.1 compatibility. - Improved scriptable XML and TXT export support (Professional edition only). - Improved Network Adaptor detection. - Improved localization and language support. - Minor GUI improvements. - Minor bug fixes.Version: 1.26.698Addon Release Date: December 11, 2014Shortcut created in: Control PanelUninstallable: YesCredit: *Reaper*NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version of Speccy. If your using a x86 system, it will install the x86 version of Speccy.Must use Win Toolkit 1.4.1.14 or higher! - 3.82 MB - 6d32fe35c4201e7ef72c0adc3b331bf7Enjoy! Edited December 12, 201410 yr by *Reaper*
January 14, 20178 yr On 16/12/2009 at 10:57 PM, *Reaper* said: HWMonitor Description HWMonitor is a hardware monitoring program that reads PC systems main health sensors : voltages, temperatures, fans speed. The program handles the most common sensor chips, like ITE® IT87 series, most Winbond® ICs, and others. In addition, it can read modern CPUs on-die core thermal sensors, as well has hard drives temperature via S.M.A.R.T, and video card GPU temperature. Special hardware monitors such as abit® uGuru and Gigabyte® ODIN? power supplies serie are supported too. Changelog:Added CPU and GPU utilization.Added DRAM power (Haswell processors).Intel X99 Platform (DDR4 and Haswell-E).Support for Windows 10.New application icon. Version: 1.26 Addon Release Date: December 12, 2014 Shortcut created in: Control Panel Uninstallable: Yes Credit: *Reaper* NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version. Must use Win Toolkit 1.4.1.14 or higher! - 1.01 MB - 9011f15f48e6ce2e49d714394ded171b Enjoy! On 26/04/2010 at 7:22 PM, *Reaper* said: Speccy Description At first glance, Speccy may seem like an application for system administrators and power users. It certainly is, but Speccy can also help normal users, in everyday computing life. If you need to add more memory to your system, for example, you can check how many memory slots your computer has and what memory's already installed. Then you can go out and buy the right type of memory to add on or replace what you've already got. If you're going to be selling your PC, you can use Speccy to quickly list out the components. Or, if you're buying a PC, you can use Speccy to check that the computer has what the label says it has. Also, Speccy comes in handy for support. If you're on the phone with technical support and they want to know what video card you have installed, there's no need to hunt around Windows. Speccy has all the information on one easy-to-understand screen. Changelog:v1.26.698 (29 Apr 2014) - Added SMART attribute real values and statuses. - Restructured SMART attributes and RAM JEDEC data into grid view. - Improved Windows 8.1 compatibility. - Improved scriptable XML and TXT export support (Professional edition only). - Improved Network Adaptor detection. - Improved localization and language support. - Minor GUI improvements. - Minor bug fixes. Version: 1.26.698 Addon Release Date: December 11, 2014 Shortcut created in: Control Panel Uninstallable: Yes Credit: *Reaper* NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version of Speccy. If your using a x86 system, it will install the x86 version of Speccy. Must use Win Toolkit 1.4.1.14 or higher! - 3.82 MB - 6d32fe35c4201e7ef72c0adc3b331bf7 Enjoy!
