Posted April 27, 201015 yr hi,Forum has this issue for a long time. please fix it.Now;Should be;if you don't know about css. here is the key;in your public/style_css/prettify.css about line 30;find:#admin_bar {background:none repeat scroll 0 0 transparent;color:#888888;font-size:0.9em;height:26px;padding:0 10px;}change it to:#admin_bar {background:none repeat scroll 0 0 transparent;color:#888888;font-size:0.9em;height:50px;padding:0 10px;}as you see, just set height to 50px. when pathway is too long, it goes under your header and I can't click main category.cheers,Alper
April 28, 201015 yr Should be working now.Hopefully, I will be able to pay for the custom skin which should be same or very similar as our frontpage skin.
April 29, 201015 yr Author Thanks @N1K. Now it's working..@N1K, in fact I don't look at home page often. Now I looked and I saw that you use Joomla! as portal, and IP.Board as forum. Isn't IP.Board free, is it? Don't take this wrong way but why you paid for forum software? If I were you, I would migrate my forum software to PHBB. it's free. and then you can use the same skin for your forum software as your frontpage skin. Rockettheme also have the same themes for PHBB forum. here is the link for PHHB forum skin;http://demo.rockettheme.com/phpbb3/Select infuse from dropdown menu. Yes, it's paid but you can offer them for free or just you can paid just for one time. in fact, if every user have clicked a few time for google advertisements, hope you can get money for PHBB skin:)cheers..
April 29, 201015 yr Yes I know, but I just like IPB and we've been using it from the start, so I don't plan to upgrade in the near future.Once we install the new skin, I kindly ask you to report any issues you may find.Regards
