I can integrate visio on DVD instalation office?
hello all, i be new in this sub, forum of office, my answer is: i can Integrate visio2007, project2007 into instalation DVD of office 2007?. i see a many version with name "OFFICE SYSTEM", it version have integrate visio and project into installation, and you chose one option.
how make it? i need office resourse kit?, extract with cmd? how it the progress for make it?
i
Hello zookey,
Move the visio.msp to another folder.
I have setup Office the same way, and have seperate installs for Publisher, Visio etc, the difference is that the msp's are in different folders, not the updates folder.
My understanding of the Updates folder is that setup applies "all" msp's (alphabetically) in that folder.
\\path to media\setup.exe /adminfile \\path to media\clientname\MSPublisher07.MSP /config \\path to media\Publisher.WW\config.xml
I found I had to specify the config file, although there is almost nothing in it. (below)
<Configuration Product="Publisher">
<USERNAME Value="clientname" />
</Configuration>
Source
See if that helps.
