[Duda] Value Folder
hola como andan se me presento una duda, si yo quiero instalar un programa en X64 cual seria el Value Folder del .inf? y se puede hacer compatible para ambas plataformas X86 y X64 en el mismo inf.
Es decir
16422 = Program Files (X86)
????? = Program Files (X64)
slds!!!!
Edited by Javo
Mismo INF no es muy practico, 5eraph el creador del updatepack para XP x64 dijo esto
# All .x86 decorations must be removed. They never should have been put into addon INFs to begin with. ;) One example is [sourceDisksNames.x86]: change it to simply [sourceDisksNames].
# Second, all references to the I386 location need to be changed to AMD64. Usually the only one is in [sourceDisksNames]. Here's an example that incorporates the change above as well:
1="Signed Theme Files","SgndThms.cab",,"i386"
must be changed to
[sourceDisksNames]
1="Signed Theme Files","SgndThms.cab",,"AMD64"
# Finally, the following values must be changed in all occurances:
* %ProgramFiles% to %ProgramFiles(x86)%
* 16422 to 16426
* 16427 to 16428
muchas gracias rick, como siempre el mas activo ayudando a usuarios de este foro.
saludos!!!!!
