February 13, 201115 yr Here is just a Basic Guide on how to a perform System File Scan within Windows 7/Vista;(For Windows XP Users you will need to insert the Installation CD to use this function)Go to Start > All Program > Accessories > Right Click Command Prompt and Run As Administrator;Type In sfc /scannow and hit enter then let it complete the scan. (Remember to put a space after sfc )Screenshot 1Screenshot 2Screenshot 3Once the scan is complete type Exit and then Reboot your ComputerThe System File Checker will look for any system files/.dll file's that are corrupt and will attempt to fix these normally following a re start of your computer.This can also be run in safemode too by selecting Safemode with command prompt privilage.Hope you found this useful!
June 9, 201312 yr oo wouldn't that mean i could uninstall bloatware in safe mode with command prompt?
