July 16, 201114 yr HomepageFeaturesDefraggler v2.12.628Use Defraggler to defrag your entire hard drive, or individual files - unique in the industry. This compact Windows application supports NTFS and FAT32 file systemsThe following install option are configured:-Add Start Menu Shortcut-Add Defraggler context menu to Windows Explorer-Replace Windows Disk Defragmenter-No google toolbarDefault is English. You have to change to your own lang in the inf. Instruction in inf, [Readme] section.(Tested only in English XP). Suggest to test in VM first.Additional info: If it is English platform, all language files are not needed. Which you can save further diskspace.(It requires you to edit manually the inf.)Defraggler2.12.628_inf_addon.cabSize: 1.45 Mb (1,516,566 bytes)MD5: CD1FDC9907FCCBAC63F0B412A5059ACB Edited December 23, 201213 yr by Geej
June 1, 201213 yr Hi Geej, there is a new version 2.10.413, when you can, thanks Edited June 1, 201213 yr by luis
November 13, 201213 yr You may want to edit your thread title and first post to the correct spelling: Defraggler
