estos son mis Tweaks que yo uso y tengo problemas con estos Tweaks desde dos o tres versiones anteriores muchos no me funcionan a ver si me podrian decir cuales eliminar o se pueden corregir o si mi problema es otro ya que yo no uso nlite para ponerlo apunto como ya es sabido es muy obsoleto el soft que ya no tiene soporte y el upl es mas actual mes a mes y trae las actualizaciones que se necesita en la actualidad para tener un windows xp sp3 a punto desde cero tambien me e dado cuenta que los puertos usb tardan demasiado en reconocerse en diferentes maquinas de prueba que tengo a ver si a alguien le pasa lo mismo o
; Tweaks para windows XP sp3 |
[general]
builddate=2011/20/05
description=Modificacion de valores del registro
forcelang=Español
language=Español
title=TweaksXPYjM
version=1.3.1
[registry_addreg]
;Benefit: Lowers the amount of disk space used by System Restore from 12% to 6%
;NOTE: This tweak permanently changes the percentage range of disk space used by System Restore.
;Instead of simply sliding the bar from 12% to 6%, it changes the range from 0%-12% (default) to
;0%-6%. The user will benefit by only having 6% of their drive space allocated to System Restore, but
;they will not be able to increase the percentage higher than 6%.
HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore","DiskPercent",0x10001,06,00,00,00
;Benefit: Reduces the aggregate amount of bandwidth programs can reserve from 20% to 0%
;NOTE: Although this tweak is only beneficial when the program that reserved the bandwidth is sending
;sufficient amounts of data, it was still included - see the below link for more info
;http://support.microsoft.com/default.aspx?scid=kb;en-us;316666
HKCU,"Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalMachine\Software\Policies\Microsoft\Windows\Psched","NonBestEffortLimit",0x10001,00,00,00,00
;Benefit: Speeds up the access of AVI folders as well as makes the renaming and deletion of AVIs easier
HKCR,"CLSID\{87D62D94-71B3-4b9a-9489-5FE6850DC73E}]"
HKCR,"SystemFileAssociations\.avi\shellex\PropertyHandler"
HKLM,"SOFTWARE\Classes\CLSID\{87D62D94-71B3-4b9a-9489-5FE6850DC73E}\InProcServer32"
;Benefit: Helps shorten the amount of time it takes to start programs by fetching and storing
;commonly used files ensures default setting [3(hex)] is activated to allow prefetching of both
;application launch and boot
;NOTE: 0(hex)=disabled, 1(hex)=Application launch prefetching, 2(hex)=Boot prefetching,
;3(hex)=Both prefetching (default)
HKLM,"SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters","EnablePrefetcher",0x10001,03,00,00,00
HKU,".DEFAULT\Control Panel\Accessibility",,0x10
HKU,".DEFAULT\Control Panel\Accessibility\Blind Access","On",0x0,"0"
HKU,".DEFAULT\Control Panel\Accessibility\HighContrast","Flags",0x0,"122"
HKU,".DEFAULT\Control Panel\Accessibility\HighContrast","High Contrast Scheme",0x0,"High Contrast Black (large)"
HKU,".DEFAULT\Control Panel\Accessibility\HighContrast","Volital HC Scheme",0x0,"High Contrast Black (large)"
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Preference","On",0x0,"0"
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","AutoRepeatDelay",0x0,"1000"
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","AutoRepeatRate",0x0,"500"
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","BounceTime",0x0,"0"
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","DelayBeforeAcceptance",0x0,"1000"
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","Flags",0x0,"122"
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","Last BounceKey Setting",0x10001,f4,01,00,00
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","Last Valid Delay",0x10001,e8,03,00,00
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","Last Valid Repeat",0x10001,f4,01,00,00
HKU,".DEFAULT\Control Panel\Accessibility\Keyboard Response","Last Valid Wait",0x10001,e8,03,00,00
HKU,".DEFAULT\Control Panel\Accessibility\MouseKeys","Flags",0x0,"58"
HKU,".DEFAULT\Control Panel\Accessibility\MouseKeys","MaximumSpeed",0x0,"80"
HKU,".DEFAULT\Control Panel\Accessibility\MouseKeys","TimeToMaximumSpeed",0x0,"3000"
HKU,".DEFAULT\Control Panel\Accessibility\SerialKeys",,0x10
HKU,".DEFAULT\Control Panel\Accessibility\ShowSounds","On",0x0,"0"
HKU,".DEFAULT\Control Panel\Accessibility\SoundSentry","Flags",0x0,"2"
HKU,".DEFAULT\Control Panel\Accessibility\SoundSentry","FSTextEffect",0x0,"0"
HKU,".DEFAULT\Control Panel\Accessibility\SoundSentry","WindowsEffect",0x0,"0"
HKU,".DEFAULT\Control Panel\Accessibility\SoundSentry","TextEffect",0x0,"0"
HKU,".DEFAULT\Control Panel\Accessibility\StickyKeys","Flags",0x0,"506"
HKU,".DEFAULT\Control Panel\Accessibility\TimeOut","Flags",0x0,"2"
HKU,".DEFAULT\Control Panel\Accessibility\TimeOut","TimeToWait",0x0,"300000"
HKU,".DEFAULT\Control Panel\Accessibility\ToggleKeys","Flags",0x0,"58"
HKCU,"Control Panel\Accessibility",,0x10
HKCU,"Control Panel\Accessibility\Blind Access","On",0x0,"0"
HKCU,"Control Panel\Accessibility\HighContrast","Flags",0x0,"122"
HKCU,"Control Panel\Accessibility\HighContrast","High Contrast Scheme",0x0,"High Contrast Black (large)"
HKCU,"Control Panel\Accessibility\HighContrast","Volital HC Scheme",0x0,"High Contrast Black (large)"
HKCU,"Control Panel\Accessibility\Keyboard Preference","On",0x0,"0"
HKCU,"Control Panel\Accessibility\Keyboard Response","AutoRepeatDelay",0x0,"1000"
HKCU,"Control Panel\Accessibility\Keyboard Response","AutoRepeatRate",0x0,"500"
HKCU,"Control Panel\Accessibility\Keyboard Response","BounceTime",0x0,"0"
HKCU,"Control Panel\Accessibility\Keyboard Response","DelayBeforeAcceptance",0x0,"1000"
HKCU,"Control Panel\Accessibility\Keyboard Response","Flags",0x0,"122"
HKCU,"Control Panel\Accessibility\Keyboard Response","Last BounceKey Setting",0x10001,f4,01,00,00
HKCU,"Control Panel\Accessibility\Keyboard Response","Last Valid Delay",0x10001,e8,03,00,00
HKCU,"Control Panel\Accessibility\Keyboard Response","Last Valid Repeat",0x10001,f4,01,00,00
HKCU,"Control Panel\Accessibility\Keyboard Response","Last Valid Wait",0x10001,e8,03,00,00
HKCU,"Control Panel\Accessibility\MouseKeys","Flags",0x0,"58"
HKCU,"Control Panel\Accessibility\MouseKeys","MaximumSpeed",0x0,"80"
HKCU,"Control Panel\Accessibility\MouseKeys","TimeToMaximumSpeed",0x0,"3000"
HKCU,"Control Panel\Accessibility\SerialKeys",,0x10
HKCU,"Control Panel\Accessibility\ShowSounds","On",0x0,"0"
HKCU,"Control Panel\Accessibility\SoundSentry","Flags",0x0,"2"
HKCU,"Control Panel\Accessibility\SoundSentry","FSTextEffect",0x0,"0"
HKCU,"Control Panel\Accessibility\SoundSentry","WindowsEffect",0x0,"0"
HKCU,"Control Panel\Accessibility\SoundSentry","TextEffect",0x0,"0"
HKCU,"Control Panel\Accessibility\StickyKeys","Flags",0x0,"506"
HKCU,"Control Panel\Accessibility\TimeOut","Flags",0x0,"2"
HKCU,"Control Panel\Accessibility\TimeOut","TimeToWait",0x0,"300000"
HKCU,"Control Panel\Accessibility\ToggleKeys","Flags",0x0,"58"
HKCR,"AllFilesystemObjects\shellex\ContextMenuHandlers\Copy To",,0x0,"{C2FBB630-2971-11D1-A18C-00C04FD75D13}"
HKCR,"AllFilesystemObjects\shellex\ContextMenuHandlers\Move To",,0x0,"{C2FBB631-2971-11D1-A18C-00C04FD75D13}"
HKLM,"SYSTEM\CurrentControlSet\Services\i8042prt\Parameters","CrashOnCtrlScroll",0x10001,01,00,00,00
HKCU,"Control Panel\Desktop","MenuShowDelay",0x0,"20"
HKU,".DEFAULT\Control Panel\Desktop","MenuShowDelay",0x0,"20"
HKCU,"Software\Microsoft\MediaPlayer\Player\Settings","EnableDVDUI",0x0,"Yes"
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings\Connections","SavedLegacySettings",0x1,3c,00,00,00,f5,04,00,00,01,00,00,00,01,00,00,00,3a,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,f9,66,72,b1,9d,c4,01,01,00,00,00,c0,a8,02,a7,00,00,00,00,00,00,00,00
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings\Connections","DefaultConnectionSettings",0x1,3c,00,00,00,09,00,00,00,01,00,00,00,01,00,00,00,3a,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,e0,f9,66,72,b1,9d,c4,01,01,00,00,00,c0,a8,02,a7,00,00,00,00,00,00,00,00
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings","PrivacyAdvanced",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3","{AEBA21FA-782A-4A90-978D-B72164C80120}",0x1,1a,37,61,59,23,52,35,0c,7a,5f,20,17,2f,1e,1a,19,0e,2b,01,73,13,37,13,12,14,1a,15,2a,4e,2c,08,0d,20,1b,28,18,36,32
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3","{A8A88C49-5EB2-4990-A1A2-0876022C854F}",0x1,1a,37,61,59,23,52,35,0c,7a,5f,20,17,2f,1e,1a,19,0e,2b,01,73,13,37,13,12,14,1a,15,39,4e,2c,08,0d,20,1b,28,18,36,32
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\3","1206",0x10001,03,00,00,00
HKLM,"SOFTWARE\Policies\Microsoft\WindowsMediaPlayer","GroupPrivacyAcceptance",0x10001,01,00,00,00
HKLM,"SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction","Enable",0x0,"Y"
HKCU,"Control Panel\Desktop","AutoEndTasks",0x0,"1"
HKU,".DEFAULT\Control Panel\Desktop","AutoEndTasks",0x0,"1"
HKCU,"Software\Microsoft\Internet Connection Wizard","Completed",0x1,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","Use Search Asst",0x0,"no"
HKCU,"Software\Microsoft\Internet Explorer\Main","Search Page",0x0,"http://www.google.co.ve"
HKCU,"Software\Microsoft\Internet Explorer\Main","Search Bar",0x0,"http://www.google.co.ve/ie_rsearch.html"
HKCU,"Software\Microsoft\Internet Explorer\SearchURL",,0x0,"http://www.google.co.ve/keyword/%%s"
HKCU,"Software\Microsoft\Internet Explorer\SearchURL","provider",0x0,"gogl"
HKLM,"SOFTWARE\Microsoft\Internet Explorer\Search","SearchAssistant",0x0,"http://www.google.co.ve/ie_rsearch.html"
HKCU,"Control Panel\Desktop","HungAppTimeout",0x0,"3000"
HKU,".DEFAULT\Control Panel\Desktop","HungAppTimeout",0x0,"3000"
HKCU,"Control Panel\Desktop","WaitToKillAppTimeout",0x0,"3000"
HKU,".DEFAULT\Control Panel\Desktop","WaitToKillAppTimeout",0x0,"3000"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\BitBucket","Percent",0x10001,02,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\BitBucket","UseGlobalSettings",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Control\CrashControl","AutoReboot",0x10001,00,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Dnscache\Parameters","MaxCacheEntryTtlLimit",0x10001,c0,a8,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Dnscache\Parameters","MaxNegativeCacheTtl",0x10001,00,00,00,00
HKCR,"CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}",,0x0,"My Computer"
HKCR,"CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}","LocalizedString",0x20000,"%%USERNAME%% on %%COMPUTERNAME%%"
HKCR,"CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}","LocalizedString",0x20000,"%%computername%%"
;-------------- Add Notepad to context menu for any file
HKCR,"*\shell",,0x10
HKCR,"*\shell\notepad.exe",,0x0,"Notepad"
HKCR,"*\shell\notepad.exe\command",,0x20000,"""%11%\notepad.exe"" ""%%1"""
;-------------- Search for All File Types.
HKLM,"SYSTEM\CurrentControlSet\Control\ContentIndex","FilterFilesWithUnknownExtensions",0x10001,01,00,00,00
;-------------- Enable automatic image resizing
HKCU,"Software\Microsoft\Internet Explorer\Main","Enable AutoImageResize",0x0,"yes"
;-------------- Enable image toolbar
HKCU,"Software\Microsoft\Internet Explorer\Main","Enable_MyPics_Hoverbar",0x0,"yes"
;----- Show image download placeholders
HKCU,"Software\Microsoft\Internet Explorer\Main","Show image placeholders",0x10001,01,00,00,00
;-------------- Always Use Clear Type for HTML
HKCU,"Software\Microsoft\Internet Explorer\Main","UseClearType",0x0,"yes"
;-------------- Set Tab Settings
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","UseMRUSwitching",0x0,"no"
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","WarnOnCloseAdvanced",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","Enabled",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","WarnOnClose",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","OpenInForeground",0x10001,00,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","OpenAllHomePages",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","OpenAdjacent",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","UseHomepageForNewTab",0x10001,00,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","QuickTabsThreshold",0x10001,02,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","PopupsUseNewWindow",0x10001,00,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\TabbedBrowsing","ShortcutBehavior",0x10001,00,00,00,00
;-------------- Adds search keywords to Internet Explorer
HKCU,"Software\Microsoft\Internet Explorer\SearchUrl\A",,0x0,"http://www.altavista.com/sites/search/web?q=%%s"
HKCU,"Software\Microsoft\Internet Explorer\SearchUrl\FM",,0x0,"http://www.filemirrors.com/search.src?file=%%s"
HKCU,"Software\Microsoft\Internet Explorer\SearchUrl\G",,0x0,"http://www.google.com/search?q=%%s"
HKCU,"Software\Microsoft\Internet Explorer\SearchUrl\L",,0x0,"http://sjc-search.sjc.lycos.com/default.asp?lpv=web&query=%%s"
HKCU,"Software\Microsoft\Internet Explorer\SearchUrl\MS",,0x0,"http://support.microsoft.com/?kbid=%%s"
HKCU,"Software\Microsoft\Internet Explorer\SearchUrl\M",,0x0,"http://search.msn.com/results.asp?q=%%s"
HKCU,"Software\Microsoft\Internet Explorer\SearchUrl\Y",,0x0,"http://search.yahoo.com/search?p=%%s"
;-------------- Add 'Google' Search Provider
HKCU,"Software\Microsoft\Internet Explorer\SearchScopes\{E50C76D9-48D9-4941-9327-A3498F3B0E84}","DisplayName",0x0,"Google"
HKCU,"Software\Microsoft\Internet Explorer\SearchScopes\{E50C76D9-48D9-4941-9327-A3498F3B0E84}","URL",0x0,"http://www.google.co.ve/search?q={searchTerms}&rls=com.microsoft:{language}&ie={inputEncoding}&oe={outputEncoding}&startIndex={startIndex?}&startPage={startPage}"
;-------------- Set 'Google as Default Search Engine in IE7'
HKCU,"Software\Microsoft\Internet Explorer\Main","SearchMigrated",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\SearchScopes","DefaultScope",0x0,"{E50C76D9-48D9-4941-9327-A3498F3B0E84}"
HKCU,"Software\Microsoft\Internet Explorer\SearchScopes","Version",0x10001,01,00,00,00
;-------------- Increase Internet Explorer's simultaneous downloads to 50 (default is 2)
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings","MaxConnectionsPerServer",0x10001,32,00,00,00
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings","MaxConnectionsPer1_0Server",0x10001,32,00,00,00
;-------------- Increase Network Throughput
HKLM,"SYSTEM\CurrentControlSet\Services\lanmanworkstation\parameters","MaxCmds",0x10001,64,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\lanmanworkstation\parameters","MaxThreads",0x10001,64,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\lanmanworkstation\parameters","MaxCollectionCount",0x10001,64,00,00,00
;-------------- Faster Web Page Loading
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\ServiceProvider","DnsPriority",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\ServiceProvider","HostsPriority",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\ServiceProvider","LocalPriority",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\ServiceProvider","NetbtPriority",0x10001,01,00,00,00
;-------------- Broadband Tweak for Windows XP
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","DefaultTTL",0x10001,80,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","EnablePMTUBHDetect",0x10001,00,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","EnablePMTUDiscovery",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","TcpMaxDupAcks",0x10001,02,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","TcpMaxDataRetransmissions",0x10001,06,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","SackOpts",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","Tcp1323Opts",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","TcpWindowSize",0x10001,c0,eb,03,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","GlobalMaxTcpWindowSize",0x10001,c0,eb,03,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","TcpTimedWaitDelay",0x10001,1e,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","ForwardBufferMemory",0x10001,00,4a,02,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","NumForwardPackets",0x10001,4a,02,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","MaxForwardBufferMemory",0x10001,00,4a,02,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","MaxNumForwardPackets",0x10001,4a,02,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","DisableTaskOffload",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Tcpip\Parameters","MTU",0x0,"1500"
;-------------- Stores more DNS entries so that your computer doesn't have to look them up as much
;-------------- Do not cache failed DNS lookups
HKLM,"SYSTEM\CurrentControlSet\Services\Dnscache\Parameters","CacheHashTableBucketSize",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Dnscache\Parameters","CacheHashTableSize",0x10001,80,01,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Dnscache\Parameters","MaxCacheEntryTtlLimit",0x10001,00,fa,00,00
HKLM,"SYSTEM\CurrentControlSet\Services\Dnscache\Parameters","MaxSOACacheEntryTtlLimit",0x10001,2d,01,00,00
;-------------- Reduces size of index.dat in cookies
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache\Cookies","CacheLimit",0x10001,00,01,00,00
HKCU,"Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache\History","CacheLimit",0x10001,00,08,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache\Content","CacheLimit",0x10001,00,08,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache\Cookies","CacheLimit",0x10001,00,01,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Cache\History","CacheLimit",0x10001,00,08,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\Content","PerUserItem",0x10001,01,00,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\Content","CachePrefix",0x0
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\Content","CacheLimit",0x10001,00,08,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\Cookies","PerUserItem",0x10001,01,00,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\Cookies","CachePrefix",0x0,"Cookie:"
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\Cookies","CacheLimit",0x10001,00,01,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\History","PerUserItem",0x10001,01,00,00,00
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\History","CachePrefix",0x0,"Visited:"
HKU,".DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\5.0\Cache\History","CacheLimit",0x10001,00,08,00,00
;-------------- Esconde bandera de windows (esquina superior derecha) de todas las ventanas
HKCU,"Software\Microsoft\Internet Explorer\Toolbar\Explorer","ITBarLayout",0x1,11,00,00,00,4c,00,00,00,00,00,00,00,34,00,00,00,13,00,00,00,55,00,00,00,05,00,00,00,6a,04,00,00,26,00,00,00,01,00,00,00,a1,06,00,00,d9,01,00,00,02,00,00,00,a1,06,00,00,f0,03,00,00,04,00,00,00,a1,04,00,00,0a,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Toolbar\ShellBrowser","ITBarLayout",0x1,11,00,00,00,4c,00,00,00,00,00,00,00,34,00,00,00,13,00,00,00,55,00,00,00,05,00,00,00,6a,05,00,00,26,00,00,00,01,00,00,00,20,07,00,00,56,00,00,00,02,00,00,00,21,07,00,00,57,00,00,00,04,00,00,00,21,05,00,00,55,01,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
;-------------- Cambia el nombre de miPC a EQUIPO
HKLM,"SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}",,0x0,"Equipo"
HKLM,"SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}","LocalizedString",0x20000,"Equipo"
;-------------- Cambia el nombre de misDocumentos a %username&
HKCR,"CLSID\{450D8FBA-AD25-11D0-98A8-0800361B1103}","LocalizedString",0x20000,"%%Username%%"
;-------------- Iconos del escritorio igual que en vista (tamaño y separacion)
HKCU,"Control Panel\Desktop\WindowMetrics","IconSpacing",0x0,"-1545"
HKCU,"Control Panel\Desktop\WindowMetrics","IconVerticalspacing",0x0,"-1440"
HKCU,"Control Panel\Desktop\WindowMetrics","Shell Icon Size",0x0,"48"
;-------------- Cursores aero en pantalla de inicio de sesion
HKU,".DEFAULT\Control Panel\Cursors","Arrow",0x20000,"%%SYSTEMROOT%%\Cursors\aero_arrow.cur"
HKU,".DEFAULT\Control Panel\Cursors","AppStarting",0x20000,"%%SYSTEMROOT%%\Cursors\aero_working.ani"
HKU,".DEFAULT\Control Panel\Cursors","Hand",0x20000,"%%SYSTEMROOT%%\Cursors\aero_link.cur"
HKU,".DEFAULT\Control Panel\Cursors","Help",0x20000,"%%SYSTEMROOT%%\Cursors\aero_helpsel.cur"
HKU,".DEFAULT\Control Panel\Cursors","Wait",0x20000,"%%SYSTEMROOT%%\Cursors\aero_busy.ani"
;-------------- Abrir archivos .nfo con notepad
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.nfo\OpenWithList","a",0x0,"NOTEPAD.EXE"
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.nfo\OpenWithList","MRUList",0x0,"a"
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.nfo\OpenWithProgids","nfo_auto_file",0x20001
;-------------- cached "folder-view settings", currently 250 (to speed-up browsing local folders)
HKCU,"Software\Microsoft\Windows\Shell","BagMRU Size",0x10001,FA,00,00,00
HKCU,"Software\Microsoft\Windows\Shell NoRoam","BagMRU Size",0x10001,FA,00,00,00
;-------------- Caching thumbnails settings
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer","ThumbnailQuality",0x10001,1E,00,00,00
;-------------- Set icon caching
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer","Max Cached Icons",0x0,"256"
;-------------- Change Drive name and icon
;-------------- You have to change the \C\ below to the drive you want to change
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer","ShowDriveLettersFirst",0x10001,02,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\DriveIcons\C\DefaultLabel",,0x0,"Local OS"
;-------------- Speed up opening of My Computer and Explorer
HKLM,"SYSTEM\CurrentControlSet\Services\stisvc","Start",0x10001,02,00,00,00
HKCU,"Software\Microsoft\Windows\CurrentVersion\Policies\Explorer","NoSaveSettings",0x10001,00,00,00,00
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced","NoNetCrawling",0x10001,01,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer","NoRemoteRecursiveEvents",0x10001,01,00,00,00
;-------------- Add Government and Military to auto url searches
HKLM,"SOFTWARE\Microsoft\Internet Explorer\Main\UrlTemplate","5",0x0,"www.%%s.gov"
HKLM,"SOFTWARE\Microsoft\Internet Explorer\Main\UrlTemplate","6",0x0,"www.%%s.mil"
HKLM,"SOFTWARE\Microsoft\Internet Explorer\Main\UrlTemplate","7",0x0,"www.%%s.gov.ve"
HKLM,"SOFTWARE\Microsoft\Internet Explorer\Main\UrlTemplate","8",0x0,"www.%%s.gob.ve"
HKLM,"SOFTWARE\Microsoft\Internet Explorer\Main\UrlTemplate","9",0x0,"www.%%s.com.ve"
;-------------- allows boot files to be placed optimally on the hard-drive for faster boots.
HKLM,"SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction","LcnStartLocation",0x0,"4592923"
HKLM,"SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction","LcnEndLocation",0x0,"4817196"
HKLM,"SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction","OptimizeComplete",0x0,"Yes"
HKLM,"SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction","OptimizeError",0x0," "
;-------------- Speed up shutdown
HKCU,"Control Panel\Desktop","HungAppTimeout",0x0,"100"
HKCU,"Control Panel\Desktop","WaitToKillAppTimeout",0x0,"2000"
HKLM,"SYSTEM\CurrentControlSet\Contro l","WaitToKillServiceTimeout",0x0,"2000"
HKLM,"SYSTEM\ControlSet001\Control","WaitToKillServiceTimeout",0x0,"2000"
HKLM,"SYSTEM\ControlSet003\Control","WaitToKillServiceTimeout",0x0,"2000"
;-------------- Disable Automatic Restart in the event of a BSOD
;-------------- Prefetcher tweak (faster booting)
HKLM,"SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters","EnablePrefetcher",0x10001,00,00,00,00
;-------------- AMD Processor Fix
;----- dword:00000100= 256KB SecondLevel Cache, dword:00000200 = 512KB SecondLevel Cache
;[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]
;"SecondLevelDataCache"=dword:00000200
;-------------- Cambiar el texto titulo barra internet
HKCU,"Software\Microsoft\Internet Explorer\Main","NoUpdateCheck",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","NoJITSetup",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","StatusBarOther",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","StatusBarWeb",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","Disable Script Debugger",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Start Page",0x0,"http://www.google.co.ve/"
HKCU,"Software\Microsoft\Internet Explorer\Main","Search Bar",0x0,"http://www.google.co.ve/ie"
HKCU,"Software\Microsoft\Internet Explorer\Main","Anchor Underline",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Cache_Update_Frequency",0x0,"Once_Per_Session"
HKCU,"Software\Microsoft\Internet Explorer\Main","Display Inline Images",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Do404Search",0x1,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","Local Page",0x0,"%11%\blank.htm"
HKCU,"Software\Microsoft\Internet Explorer\Main","Save_Session_History_On_Exit",0x0,"no"
HKCU,"Software\Microsoft\Internet Explorer\Main","Show_FullURL",0x0,"no"
HKCU,"Software\Microsoft\Internet Explorer\Main","Show_StatusBar",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Show_ToolBar",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Show_URLinStatusBar",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Show_URLToolBar",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Use_DlgBox_Colors",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","XMLHTTP",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","AlwaysShowMenus",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","Enable Browser Extensions",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Play_Background_Sounds",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Play_Animations",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","CompatibilityFlags",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","FullScreen",0x0,"no"
HKCU,"Software\Microsoft\Internet Explorer\Main","SearchMigrated",0x10001,00,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","Window_Placement",0x1,2c,00,00,00,02,00,00,00,03,00,00,00,00,83,ff,ff,00,83,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,74,00,00,00,74,00,00,00,94,03,00,00,b2,02,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","RunOnceHasShown",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","RunOnceComplete",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Internet Explorer\Main","Use FormSuggest",0x0,"no"
HKCU,"Software\Microsoft\Internet Explorer\Main","NotifyDownloadComplete",0x0,"yes"
HKCU,"Software\Microsoft\Internet Explorer\Main",,0x0,"http://www.games-fusion.net"
HKCU,"Software\Microsoft\Internet Explorer\Main","Check_Associations",0x0,"no"
HKCU,"Software\Microsoft\Internet Explorer\Main","Error Dlg Displayed On Every Error",0x0,"no"
HKCU,"Software\Microsoft\Internet Explorer\Main","Window Title",0x0,"Windows Internet Explorer proporcionado por Microsoft"
HKCU,"Software\Microsoft\Internet Explorer\Main","ShowedCheckBrowser",0x0,"Yes"
HKCU,"Software\Microsoft\Internet Explorer\Main","Save Directory",0x0,"%24%"
HKCU,"Software\Microsoft\Internet Explorer\Main\Default Feeds",,0x10
HKCU,"Software\Microsoft\Internet Explorer\Main\Default Feeds\{4FC30FBE-5840-4D60-95A1-F31A72D3323E}","Title",0x0,"Microsoft Feeds\Microsoft at Work"
HKCU,"Software\Microsoft\Internet Explorer\Main\Default Feeds\{4FC30FBE-5840-4D60-95A1-F31A72D3323E}","Url",0x0,"http://go.microsoft.com/fwlink/?LinkId=68929"
HKCU,"Software\Microsoft\Internet Explorer\Main\Default Feeds\{61514B30-E2EC-4321-91BC-22F553CCB917}","Title",0x0,"Microsoft Feeds\Microsoft at Home"
HKCU,"Software\Microsoft\Internet Explorer\Main\Default Feeds\{61514B30-E2EC-4321-91BC-22F553CCB917}","Url",0x0,"http://go.microsoft.com/fwlink/?LinkId=68928"
;-------------- Activar Filtro Phishing en Internet Explorer
HKCU,"Software\Microsoft\Internet Explorer\PhishingFilter","Enabled",0x10001,02,00,00,00
;-------------- Desactivar buscar actualizaciones en Internet Explorer
;-------------- Forzar descarga de DLL's en memoria
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\AlwaysUnloadDLL",,0x0,"1"
;------------ To be used manually when windows will not set hard drives or optical drives to DMA mode
;------------ (this tweak does not mean that your drives will be in DMA mode, you will still have to do that yourself)
HKLM,"SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0001","MasterDeviceTimingModeAllowed",0x10001,ff,ff,ff,ff
HKLM,"SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0001","SlaveDeviceTimingModeAllowed",0x10001,ff,ff,ff,ff
HKLM,"SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0002","MasterDeviceTimingModeAllowed",0x10001,ff,ff,ff,ff
HKLM,"SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0002","SlaveDeviceTimingModeAllowed",0x10001,ff,ff,ff,ff
;-------------- Disable Internet Explorer Auto-Complete prompt
HKCU,"Software\Microsoft\Internet Explorer\IntelliForms","AskUser",0x10001,00,00,00,00
;-------------- Windows Update - Deshabilitar
HKLM,"Software\Policies\Microsoft\Windows\WindowsUpdate\AU","NoAutoUpdate",0x10001,01,00,00,00
HKCU,"Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\WindowsUpdate\DisableWindowsUpdateAccess",,0x10
HKCU,"Software\Microsoft\Windows\CurrentVersion\Policies\Explorer","NoWindowsUpdate",0x10001,01,00,00,00
HKLM,"Software\Microsoft\Windows\CurrentVersion\Policies\Explorer","NoWindowsUpdate",0x10001,01,00,00,00
HKLM,"Software\Policies\Microsoft\Windows\WindowsUpdate\AU","AUOptions",0x10001,01,00,00,00
HKLM,"Software\Policies\Microsoft\Windows\WindowsUpdate",,0x10
HKCU,"Software\Microsoft\Windows\CurrentVersion\Policies\WindowsUpdate",,0x10
HKCU,"Software\Microsoft\Windows\CurrentVersion\Policies\Explorer","NoDevMgrUpdate",0x10001,01,00,00,00
;-------------- Desactivar actualizaciónes automáticas de windows media player
HKLM,"SOFTWARE\Policies\Microsoft\WindowsMediaPlayer","DisableAutoUpdate",0x10001,01,00,00,00
;-------------- Desabilita el asistente de limpieza en el escritorio
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz","NoRun",0x10001,01,00,00,00
;-------------- Lanzamiento del navegador IE en procesos separados
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\BrowseNewProcess","BrowseNewProcess",0x0,"YES"
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\BrowseNewProcess","BrowseNewProcess",0x0,"NO"
;-------------- Speed up NTFS
HKLM,"SYSTEM\CurrentControlSet\Control\FileSystem","Win31FileSystem",0x10001,00,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Control\FileSystem","Win95TruncatedExtensions",0x10001,01,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Control\FileSystem","NtfsDisableLastAccessUpdate",0x10001,01,00,00,00
;-------------- Hora Venezuela
HKLM,"SYSTEM\CurrentControlSet\Control\TimeZoneInformation","Bias",0x00010001,0e,01,00,00
HKLM,"SYSTEM\CurrentControlSet\Control\TimeZoneInformation","StandardName",0x00000000,"Hora estándar de Venezuela"
HKLM,"SYSTEM\CurrentControlSet\Control\TimeZoneInformation","StandardBias",0x00010001,00,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Control\TimeZoneInformation","StandardStart",0x00000001,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Control\TimeZoneInformation","DaylightName",0x00000000,"Hora estándar de Venezuela"
HKLM,"SYSTEM\CurrentControlSet\Control\TimeZoneInformation","DaylightBias",0x00010001,00,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Control\TimeZoneInformation","DaylightStart",0x00000001,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
HKLM,"SYSTEM\CurrentControlSet\Control\TimeZoneInformation","ActiveTimeBias",0x00010001,0e,01,00,00
HKLM,"SYSTEM\ControlSet001\Control\TimeZoneInformation","Bias",0x00010001,0e,01,00,00
HKLM,"SYSTEM\ControlSet001\Control\TimeZoneInformation","StandardName",0x00000000,"Hora estándar de Venezuela"
HKLM,"SYSTEM\ControlSet001\Control\TimeZoneInformation","StandardBias",0x00010001,00,00,00,00
HKLM,"SYSTEM\ControlSet001\Control\TimeZoneInformation","StandardStart",0x00000001,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
HKLM,"SYSTEM\ControlSet001\Control\TimeZoneInformation","DaylightName",0x00000000,"Hora estándar de Venezuela"
HKLM,"SYSTEM\ControlSet001\Control\TimeZoneInformation","DaylightBias",0x00010001,00,00,00,00
HKLM,"SYSTEM\ControlSet001\Control\TimeZoneInformation","DaylightStart",0x00000001,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
HKLM,"SYSTEM\ControlSet001\Control\TimeZoneInformation","ActiveTimeBias",0x00010001,0e,01,00,00
HKLM,"SYSTEM\ControlSet002\Control\TimeZoneInformation","Bias",0x10001,2c,01,00,00
HKLM,"SYSTEM\ControlSet002\Control\TimeZoneInformation","StandardName",0x0,"Hora est. del Pacífico de SA"
HKLM,"SYSTEM\ControlSet002\Control\TimeZoneInformation","StandardBias",0x10001,00,00,00,00
HKLM,"SYSTEM\ControlSet002\Control\TimeZoneInformation","StandardStart",0x1,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
HKLM,"SYSTEM\ControlSet002\Control\TimeZoneInformation","DaylightName",0x0,"Hora est. del Pacífico de SA"
HKLM,"SYSTEM\ControlSet002\Control\TimeZoneInformation","DaylightBias",0x10001,00,00,00,00
HKLM,"SYSTEM\ControlSet002\Control\TimeZoneInformation","DaylightStart",0x1,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
HKLM,"SYSTEM\ControlSet002\Control\TimeZoneInformation","ActiveTimeBias",0x10001,2c,01,00,00
;-------------- Teclado Español International
HKCU,"Control Panel\International","iCountry",0x0,"58"
HKCU,"Control Panel\International","iCurrDigits",0x0,"2"
HKCU,"Control Panel\International","iCurrency",0x0,"2"
HKCU,"Control Panel\International","iDate",0x0,"1"
HKCU,"Control Panel\International","iDigits",0x0,"2"
HKCU,"Control Panel\International","iLZero",0x0,"1"
HKCU,"Control Panel\International","iMeasure",0x0,"0"
HKCU,"Control Panel\International","iNegCurr",0x0,"12"
HKCU,"Control Panel\International","iTime",0x0,"0"
HKCU,"Control Panel\International","iTLZero",0x0,"1"
HKCU,"Control Panel\International","Locale",0x0,"0000200A"
HKCU,"Control Panel\International","s1159",0x0,"a.m."
HKCU,"Control Panel\International","s2359",0x0,"p.m."
HKCU,"Control Panel\International","sCountry",0x0,"Venezuela"
HKCU,"Control Panel\International","sCurrency",0x0,"Bs"
HKCU,"Control Panel\International","sDate",0x0,"/"
HKCU,"Control Panel\International","sDecimal",0x0,","
HKCU,"Control Panel\International","sLanguage",0x0,"ESV"
HKCU,"Control Panel\International","sList",0x0,","
HKCU,"Control Panel\International","sLongDate",0x0,"dddd, dd' de 'MMMM' de 'yyyy"
HKCU,"Control Panel\International","sShortDate",0x0,"dd/MM/yyyy"
HKCU,"Control Panel\International","sThousand",0x0,"."
HKCU,"Control Panel\International","sTime",0x0,":"
HKCU,"Control Panel\International","sTimeFormat",0x0,"hh:mm:ss tt"
HKCU,"Control Panel\International","iTimePrefix",0x0,"0"
HKCU,"Control Panel\International","sMonDecimalSep",0x0,","
HKCU,"Control Panel\International","sMonThousandSep",0x0,"."
HKCU,"Control Panel\International","iNegNumber",0x0,"1"
HKCU,"Control Panel\International","sNativeDigits",0x0,"0123456789"
HKCU,"Control Panel\International","NumShape",0x0,"1"
HKCU,"Control Panel\International","iCalendarType",0x0,"1"
HKCU,"Control Panel\International","iFirstDayOfWeek",0x0,"6"
HKCU,"Control Panel\International","iFirstWeekOfYear",0x0,"0"
HKCU,"Control Panel\International","sGrouping",0x0,"3;0"
HKCU,"Control Panel\International","sMonGrouping",0x0,"3;0"
HKCU,"Control Panel\International","sPositiveSign",0x0
HKCU,"Control Panel\International","sNegativeSign",0x0,"-"
HKCU,"Control Panel\International\Geo","Nation",0x0,"249"
HKCU,"Keyboard Layout",,0x10
HKCU,"Keyboard Layout\IMEtoggle",,0x10
HKCU,"Keyboard Layout\IMEtoggle\scancode",,0x10
HKCU,"Keyboard Layout\Preload","1",0x0,"00000c0a"
HKCU,"Keyboard Layout\Substitutes","00000c0a",0x0,"0000040a"
HKCU,"Keyboard Layout\Toggle","Hotkey",0x0,"3"
HKCU,"Keyboard Layout\Toggle","Language Hotkey",0x0,"3"
HKCU,"Keyboard Layout\Toggle","Layout Hotkey",0x0,"3"
HKCU,"Control Panel\Keyboard","InitialKeyboardIndicators",0x0,"2"
HKCU,"Control Panel\Keyboard","KeyboardDelay",0x0,"1"
HKCU,"Control Panel\Keyboard","KeyboardSpeed",0x0,"31"
;-------------- "Recycle Bin in Start Menu"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}",,0x0,"@%%SystemRoot%%\system32\SHELL32.dll,-8964"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}","InfoTip",0x0,"@%%SystemRoot%%\system32\SHELL32.dll,-22915"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\DefaultIcon",,0x0,"%%SystemRoot%%\system32\shell32.dll,32"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\InProcServer32",,0x20000,"%%SystemRoot%%\system32\shdocvw.dll"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\InProcServer32","ThreadingModel",0x0,"Apartment"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Instance","CLSID",0x0,"{3f454f0e-42ae-4d7c-8ea3-328250d6e272}"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Instance\InitPropertyBag","CLSID",0x0,"{13709620-C279-11CE-A49E-444553540000}"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Instance\InitPropertyBag","method",0x0,"ShellExecute"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Instance\InitPropertyBag","Command",0x0,"@%%SystemRoot%%\system32\SHELL32.dll,-8964"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\Instance\InitPropertyBag","Param1",0x0,"::{645FF040-5081-101B-9F08-00AA002F954E}"
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\shellex\ContextMenuHandlers\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}",,0x0
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\shellex\MayChangeDefaultMenu",,0x0
HKCR,"CLSID\{2559a1f6-21d7-11d4-bdaf-00c04f60b9f0}\ShellFolder","Attributes",0x10001,00,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","Type",0x0,"checkbox"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","Text",0x0,"@%%SystemRoot%%\system32\SHELL32.dll,-8964"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","HKeyRoot",0x10001,01,00,00,80
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","RegPath",0x0,"Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","ValueName",0x0,"Start_ShowOEMLink"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","CheckedValue",0x10001,01,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","UncheckedValue",0x10001,00,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","DefaultValue",0x10001,01,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink","NoOEMLinkInstalled",0x10001,00,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink\Policy\NoOEMLinkInstalled","RegKey",0x0,"Software\Microsoft\Windows\CurrentVersion\Explorer\StartMenu\StartPanel\ShowOEMLink"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop","RegPath",0x0,"Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop","Text",0x0,"Show Recycle Bin icon on the desktop"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop","Type",0x0,"checkbox"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop","ValueName",0x0,"{645FF040-5081-101B-9F08-00AA002F954E}"
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop","CheckedValue",0x10001,00,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop","UncheckedValue",0x10001,01,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop","DefaultValue",0x10001,00,00,00,00
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\RecycleBinOnDesktop","HKeyRoot",0x10001,01,
;-------------- Desabilita el cache de Thumbs.db
HKCU,"Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced","DisableThumbnailCache",0x10001,01,00,00,00
;------------------------------- End
[registry_delreg]
;-------------- Speeds up copying/moving of zip files (disable windows built in zip functionality)
HKCR,".zip\CompressedFolder"
HKCR,"CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}"
HKLM,"SOFTWARE\Classes\CompressedFold er"
;-------------- Desabilitar el centro de bienvenida de Windows
HKCU,"Software\Microsoft\Windows\CurrentVersion\Run","WindowsWelcomeCenter"
Ultima Sesión.ini
[Main]
Env = 1.4.9.1 - 2.0.50727.4927.Microsoft Windows NT 6.1.7600.0
Target = Windows XP Professional SP3 - 5.1.2600.5512 - Español - España (alfabetización internacional)
[Tasks]
Hotfixes and Update Packs
Create a Bootable ISO
Options
[Components]
;# Compatibilidad #
[KeepFiles]
msconfig.exe
[RemoveFiles]
clock.avi
[Options]
ProfilesDir = "%SystemDrive%\Documents and Settings"
TargetPath = "WINDOWS"
temp_dir = %USERPROFILE%\Configuración local\Temp
AdvTweaks
[Patches]
TcpIp = 16777215
UsbPoll = 1000
DoUxTheme
DoSFC
[services2]
wuauserv,4
[Tweaks]
[unattended]
ComputerType = Automático
MaximumDataStorePercentOfDisk = 12
RestorePointLife = 12
DesktopTheme = Por Defecto||
AutoUDay = 5
AutoUHour = 15
ProgFilesPath = "\Archivos de programa"
[NetAdapter1]
connname = ""
macaddress = ""
ipaddress = "192.168.0.1"
subnetmask = "255.255.255.0"
defaultgateway = ""
dnsserver1 = ""
dnsserver2 = ""
winsserver = ""
netbiossetting = "0"
ipxnetworknumber = "00000000"
ipxnetworkframetype = "0xFF"
[NetAdapter2]
connname = ""
macaddress = ""
ipaddress = "192.168.0.2"
defaultgateway = ""
dnsserver1 = ""
dnsserver2 = ""
winsserver = ""
[GuiRunOnce]
[Drivers]
[Hotfixes]
C:\UP\Ricks_XPsp3esUpdatePack1.5.1.7z
C:\UP\Ricks_HoldEm_es.7z
C:\UP\Ricks_SonidosUltimate_es.7z
C:\UP\Ricks_PunterosAero_es.7z
C:\UP\Ricks_TemasMicrosoft1.0.7z
C:\UP\Ricks_VenezuelaTZChange.7z
C:\UP\Ricks_WindowsEasyTransfer_es.7z
C:\UP\YJM_WinRar.7z
C:\UP\Ricks_7-Zip9.20.04_Intl_addon.7z
C:\UP\m0Zky_OOBE_Addon_Win7.7z
C:\UP\JCM_NotePad2_ESP.zip
C:\UP\BDBD_Addon_DaRk_MaDnEsS_2.5.7z
C:\UP\dude.GenuineAdvantage.v1.9.40.0.AddOn.26.03.2009.7z
C:\UP\Tweaks.7z
C:\UP\Ricks_Shockwave11.5.10.620.7z
C:\UP\Ricks_MCExtras_es.7z
C:\UP\Ricks_AdobeReaderX10.0.1_es.7z
C:\UP\Ricks_jre1.6.0_26_es.7z
como aporte ay artas que no sabia jeje
lo que yo hago es agregarlos directamente a nlite.inf como dice ricktendo en este post
Asi se hace
@JCM los tweaks son agregados a la seccion [T] en nlite.inf y son aplicados 2 veces, una vez temprano en la instalacion y la otra duranted T-13 cuando la seccion es llamado por el RunOnce en la seccion [TO]
[TO]
HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce","nlite_post_s01",0x00000000,"rundll32 advpack.dll,LaunchINFSection nlite.inf,U"
P.D. en otra nota, ie.inf y wmp.inf tienen secciones donde pueden poner tweaks para que sean aplicados durante primer inicio
y hasta el momento ningun problema
PD: Seria bueno tambien saber cuales no te funcionan por ejemplo
yo las tengo agregadas com HKLM no HKCU
Edited by jonydread
