January 10, 201213 yr hi everyone!when i try to test windows 7 x64 on virtualbox 4.1.8 and error appear like this:"Attempting to load a 64-bit application, however this CPU is not compatible with 64-bit mode.".have tried it on vmware ,pc virtual but same thing.My laptop is core 2,NO VIRTUALIZATION FEATURE IN BIOS. Have other way to test on virtual machine ?thanks advance.here info:current os on laptop :windows 7 x64CPU :64bit intel (checked with cpu-z)Virtualization feature on board: NOOCT/0911 Edited January 10, 201213 yr by 10060
January 13, 201213 yr Is your virtual machine set as a 64 bit OS? If set to 32 bit, you will likely get the error.
January 13, 201213 yr Its not the bios it is the CPU it doesnt support running 64 bit in virtualization.
