January 25, 201214 yr Hi,first of all, great tool, I love it But i've got some questions. I used W7T to integrate some Drivers, all available updates and did some minor tweaks to an Win7Pro x64 image. All went fine and i was happy with my bootable USB-Stick.Today i checked if there are some new updates on Solor and it downloaded 3 Updates. So i startet AIO-Tool, selected the .wim on my USB-Stick and loaded the preset of my last session with it. Then i added this 3 updates to the integrationlist, additionally checked the "delete Winsxs\Backup" option in component-removal-tab and clicked start.It started like expected, mounted the image to my ssd and integrated the 3 updates. But right now its on the way to integrate all the 400+ drivers again i already integrated in the last session with this wim. Is this the normal behavior? Do they need to be reintegrated? Or is it just my fault that i didnt clear the driverslist? I was afraid, that when i clear it, all the drivers already integrated in last session would be deleted. Besides, what about the tweaks i did in the first session, when i alter some things in a next session and uncheck them? Will the tweaks already saved in the image be revoked?Thanks in advance for answering my questions.Cheers Ochsefisch
January 25, 201214 yr Author So, when I want to alter an image, i should start with an empty preset and check only the things i want to alter in addition? This implies i still have in mind what i've done the last time, or i need to load the preset, have a look and then havte to start over again *g*Whats up with additions or tweaks i've done before to this image, is there any possibilty to remove them or at least see what has been done to this image compared to a "clean" win7 sp1 image? Or do i have to start over again with a clean image when i want/need to revoke some changes?
January 25, 201214 yr If you have done everything before in a previous task then all you need to do is open All-In-One tool with no preset ('Continue (Skip)' button) then just add those 3 updates and click start.
