January 28, 201214 yr ...I have selected my images, made my choices on each tab, and started the process. I then went and selected my unattended options and created an ISO. I was thrilled because it only took about 2.5 hours and I thought we had ourselves an AIO Win7 install disk.My test in VirtualBox wasn't unattended and none of the silent installers seemed to have run... I shut it down before I looked to see if the updates were installed because I am obviously going to have ot redo the thing.I looked around the tutorials but couldn't find anything... I am a bit tired though, and a few Heinekens in me... can somebody post a link for the ID10T that can't find his hand in the dark? Not sure what I missed.Thanks very much in advance,S
January 29, 201214 yr Check this out - http://www.wincert.net/forum/index.php?/topic/9217-proyecto-windows-7-sp1-actualizado/ - it's in Spanish, but Google translate does a pretty good job.Cheers and Regards
January 29, 201214 yr Author Thanks for the link bp... I'm reading now that there is an issue with the unattended part of the AIO tool. That seems to be my major issue right now.I've actually tried to use the setupcomplete.cmd to no avail. Anybody got advice on that method?
February 19, 201213 yr hi you need to have a folder in your sources folder$OEM$with 2 folders $1& $$in the $1 foldermake a folder called Install put your silent install stuff in there ie:install_flash_player_11_active_x_64bit.exein the $$ folder make afolder called SETUPin the SETUP foldermake a folder called SCRIPTSput a SetupComplete.cmdlike this exsampleCLS@echo offEcho........................................Echo..........Install FlashPlayer Pluginstart /wait %AppsRoot%\Install\install_flash_player_11_active_x_64bit.exe -installEcho..................Installed.............Echo..................Cleaning Up...........RD /S /Q %AppsRoot%\installExitthen it will execute the setup complete beore loading the desktophope this hepls
February 19, 201213 yr Author Thanks Bob... got the setupcomplete working.Do you all recommend integrating the unattended.xml before using the All in One tool? I'm figuring that maybe the file needs to be rebuilt into the images and doing that part first may help.-S
June 25, 201213 yr CLS@echo offEcho........................................Echo..........Install FlashPlayer Pluginstart /wait %AppsRoot%\Install\install_flash_player_11_active_x_64bit.exe -installEcho..................Installed.............Echo..................Cleaning Up...........RD /S /Q %AppsRoot%\installExitworks but command RD does not remove the install folder
