plz ,help me crear .cpl file ?
Hello
Friends I created some tools and i want to generate a cpl file from them
i hope you know a free prog .
i have cpl file greater but it is demo and the generated file appear a dialog to say it is demo
Ok here goes I ahve 2 ways of doing this: either a .cpl file or through the registry. I wll make it for you however you want (I have a licensed cpl generator). I need 3 things = the name and location of the exe file, an icon to be displayed and a short discription of the prog for the tooltip.
HELL I will build the addon 4 you...
thanks 4 all
and i'll attach the file ( but i need to finish it first )
thename : Vistadesk.exe
path : %windir%\system32\
tip : Vista Display Properties
icon : like that of vista ( IT IS COMMON ON THE NET)
thanks 4 all ;)
