March 15, 201214 yr Hy!I got these error. How can i fix these errors, to mount wim files?Description: Could not mount boot.wim - FixedStatus: x86[3744] OpenFilterPort:(326): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[3744] FltCommVerifyFilterPresent:(630): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[3744] WIMMountImageHandle:(764): The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.[3744] StateStoreRemoveMountedImage:(1041): The system cannot find the file specified.[3744] WIMMountImageHandle:(987): The system cannot find the file specified.Exception: D:\Windows 7 Home Premium SP1 x86 ENG MSDN\en_windows_7_home_premium_with_sp1_x86_dvd_620895\SOURCES\boot.wim---ImageX Tool for WindowsCopyright (C) Microsoft Corp. All rights reserved.Version: 6.1.7601.21716Mounting: [D:\Windows 7 Home Premium SP1 x86 ENG MSDN\en_windows_7_home_premium_with_sp1_x86_dvd_620895\SOURCES\boot.wim, Microsoft Windows Setup (x86)] -> [C:\W7T\Boot]...[ 0% ] Mounting progressError mounting image.The service cannot be started, either because it is disabled or because it hasno enabled devices associated with it.
March 15, 201214 yr What version of Windows are you using? What version of WAIK do you have installed?I got your log, you're using Windows XP. Edited March 15, 201214 yr by Legolash2o
