SoLoR Additions Problem
I added the following additions and my image wouldn't boot...
\SoLoR\03-19-12\Additions\KB917607.Windows.Help.(WinHlp32.exe)\Windows6.1-KB917607-x64.msu
\_Updates\SoLoR\03-19-12\Additions\KB943790.Windows.File.Management.API.(Fmapi.dll)\Windows6.1-KB943790-x64.msu
\_Updates\SoLoR\03-19-12\Additions\KB969168.Microsoft.Agent\Windows6.1-KB969168-x64.msu
\_Updates\SoLoR\03-19-12\Additions\KB971033.Windows.Activation.Technologies\Windows6.1-KB971033-x64.msu
\_Updates\SoLoR\03-19-12\Additions\KB974405.Windows.Identity.Foundation\Windows6.1-KB974405-x64.msu
\_Updates\SoLoR\03-19-12\Additions\KB974405.Windows.Identity.Foundation\Hotfixes\Windows6.1-KB2607496-v3-x64.msu
\_Updates\SoLoR\03-19-12\Additions\KB2607070.Windows.Update.Agent\CABsForDISM\x64\KB2607070-WUClient-SelfUpdate-ActiveX.cab
\_Updates\SoLoR\03-19-12\Additions\KB2607070.Windows.Update.Agent\CABsForDISM\x64\KB2607070-WUClient-SelfUpdate-Aux-TopLevel.cab
\_Updates\SoLoR\03-19-12\Additions\KB2607070.Windows.Update.Agent\CABsForDISM\x64\KB2607070-WUClient-SelfUpdate-Core-TopLevel.cab
http://clip2net.com/s/1Jzri
The image without them booted fine...
Edited by compstuff
I eliminated the cabs and still have it fail when I try all 6 so I evetually gave up and added them a different way but I will try again today since the Toolkit has had so many updates since I last tried
I added the 6 msu files and did not add the 3 cab files. It worked fine.
I started from scratch using v140-7 and my Technet x64 ENT image...
Step 1 integrated IE9 and Hotfix - perfect
Step 2 integrated 336 updates - perfect
Step 3 integrated 6 additions as updates - only 1 installed others failed
I have never been able to successfully get all 6 to provide me a bootable fully working ISO so I gave up and have been handling them differently (as silent installers with switches and that works for me) but this is interesting because it shows the Hotfix for WI Foundation installed but not WI Foundation
http://clip2net.com/s/1KXLl
EDIT: Another odd thing is that previously I was able to integrate KB971033 with no problem now after two different tries I can't seem to integrate it
http://clip2net.com/s/1KYPC
Edited by compstuff
