Default Theme
Hey guys, I need a little help here. Okay I'm using nlite and have an install disk almost the way I want it now but I was wondering what I can change in the Signed Themes Addon Pack to make Royale Noir be the default theme and maybe a different wallpaper too. Thanks to anyone willing to help me out here. :)
Its easy...
If you use nLite to make your CD unattended then just add this anywhere in your WINNT.SIF file (Change YourTheme.theme to whatever you want)
[shell]
CustomDefaultThemeFile="%ResourceDir%\Themes\YourTheme.theme"
For your default wallpaper uncompress the addon and also the CAB file with all the .theme and .msstyles files (5eraph might have renamed the extention .the to make it 8.3 filename compliant)
Now open the .theme or .the file in notepad and change this to the location of your wallpaper
[Control Panel\Desktop]
Recompress it as it was before and integrate it into your CD (I use TUGZip to make my CAB archives)
