Visual Studio / [Slim] .NET Framework 4 Full x86/x64?
Rick, éstos instaladores tuyos funcionan para nosotros??
Microsoft Visual C++ 2005/2008/2010, Microsoft Visual F# 2.0, Microsoft Visual J# 2.0 redistributable packages (with setup junk removed.) Also includes "extra" Visual Basic and C runtimes (see list bellow).
http://www.wincert.n...butable-x86x64/
This package contains the full version of the x86/x64 .NET Framework 4 installer including (SoLoR) updates already integrated. The reason its called "Slim" is because the original MSI installers were edited to remove unnecessary setup junk (special thanks to yumeyao,dumpydooby) this should save you 200+ MB of space on your HDD/SSD.
http://www.wincert.n...6x64-6-12-2012/
Son sólo para Windows 7 o también funcionan en XP?
Gracias!
Edited by JCM
Gracias!
Hi, can you send the link it doesn't show right
Hi, that link?
gracias Rick! cual es el orden para instalar el Language Pack? lo pregunto porque quiero hacer un instalador independiente, para no estar descompimiendo y comprimiendo cada vez que actualices en .NET Framework 4
Un Saludo!
