May 8, 201412 yr Use COM methods and properties via the COM Automation objects support.So I translate a Delphi script to Inno Setup section.And it work! Here is a part of script in [code] section:[code]http://www.jrsoftware.org)There are someway to pin taskbar depend on one's choice.We can add a [task] section in InnoSetup.if one do not want to see the "task selected page"(like me ),the second way is to create a new CheckBox in Inno [code] section.And in the second way one need to control the CheckBox show or hide inprocedure CurPageChanged().then call the function like: zylPinAppToTaskbar('c:\window', 'notepad.exe'); An example project for Unicode Inno Setup is provided as download.The attachment "pintaskbar.zip" is the script.Unzip the file pintaskbar.zip,you can get two files named "PinShortcutOntoTaskbar-task.iss"and "PinShortcutOntoTaskbar-checkbox.iss".Please copy the *.iss files to the directory: ./Inno Setup 5/ExamplesThen build the program and run PinTaskbar.exe. Referenceshttp://blog.csdn.net/ccrun/article/details/6906471http://gallery.technet.microsoft.com/ScriptCenter/b66434f1-4b3f-4a94-8dc3-e406eb30b750/http://www.codeproject.com/Tips/713824/Pin-a-shortcut-onto-the-Taskbar-or-Start-Menu The following is the script of the second way, I think you can modify it to the first way.If the attachment was broken, copy the following script to a *.iss file. ; -- PinShortcutOntoTaskbar.iss --; Pin a shortcut onto taskbar on Win7 & Win8.; @author: Yaliang.Zhao <shuangxiang2008@google.com>; @brief: I test is on 32-bit Win7 & Win8, but; I thins it will work on X64 version.[setup]AppName=PinTaskbarAppVersion=1.0OutputBaseFilename=PinTaskbarDefaultDirName={pf}\PinTaskbarOutputDir=./DisableStartupPrompt=yesDisableReadyPage=yes[Files]Source: "MyProg.exe"; DestDir: "{app}";[Tasks];Name: pintaskbar; Description: "Pin shortcut onto taskbar";Following is how to use[Code]varPinTaskBarCheck : TNewCheckBox;//the function is work well on Unicode Inno Setup,//if Non Unicode Inno Setup, one need to modify,//and I think you can do it!//Inno use Win32 APIfunction LoadLibrary(lpFilename : String) : LongInt;external 'LoadLibraryW@kernel32.dll stdcall delayload'; //if Non Unicode Inno Setup, use LoadLibraryAfunction FreeLibrary(hModule : LongInt) : BOOL;external 'FreeLibrary@kernel32.dll stdcall delayload';function LoadString(hInstance:LongInt; uId:UINT; lpBuffer:String; nBufferMax:Integer) : Integer;external 'LoadStringW@user32.dll stdcall delayload'; //if Non Unicode Inno Setup, use LoadStringA//here is the function//@param strPath The App's directory,//@param strApp The App's name//@example zylPinAppToTaskbar('c:\window', 'notepad.exe');procedure zylPinAppToTaskbar(strPath, strApp: string); var vShell, vFolder, vFolderItem, vItemVerbs: Variant; vPath, vApp: Variant; i: Integer; sItem: String; h: LongInt; szPinName: String; filenameEnd : Integer; filename : String; strEnd : String;begin SetLength(szPinName, 255); h := LoadLibrary(ExpandConstant('{sys}\Shell32.dll')); LoadString(h, 5386, szPinName, 255); FreeLibrary(h); strEnd := #0; filenameEnd := Pos(strEnd, szPinName); filename := Copy(szPinName, 1, filenameEnd - 1); if (Length(filename) > 0) then //WinXp or lower, no pin taskbar function begin vShell := CreateOleObject('Shell.Application'); vPath := strPath; vFolder := vShell.NameSpace(vPath); vApp := strApp; vFolderItem := vFolder.ParseName(vApp); vItemVerbs := vFolderItem.Verbs; for i := 1 to vItemVerbs.Count do begin sItem := vItemVerbs.Item(i).Name; if (sItem = filename) then begin // 63 63 72 75 6E 2E 63 6F 6D vItemVerbs.Item(i).DoIt; break; end; end; end;end; //You can use zylPinAppToTaskbar like thisprocedure CurPageChanged(CurPageID: Integer);begin //When Finished page is shown, call the function //You can also call is when the "Finish" button clicked. if CurPageID <> wpWelcome then PinTaskBarCheck.hide else begin PinTaskBarCheck.show; end; if CurPageID = wpFinished then begin //if IsTaskSelected('pintaskbar') then //if Selected the [task] // zylPinAppToTaskbar(ExpandConstant('{app}'), 'MyProg.exe'); if PinTaskBarCheck.Checked then zylPinAppToTaskbar(ExpandConstant('{app}'), 'MyProg.exe'); end;end;procedure InitializeWizard;begin PinTaskBarCheck := TNewCheckBox.Create(WizardForm); with PinTaskBarCheck do begin Parent := WizardForm; Caption := 'Pin it onto taskbar'; Top := 200; Left := 200; Width := ScaleY(200); Height := ScaleY(15); State := cbChecked; //Hide; end;end;pintaskbar.zip Edited May 9, 201412 yr by shuangxiang2008@googlemail
May 8, 201412 yr Anybody know how use this code in InnoSetup with a example...?Thanks and regards... ;-)
May 9, 201412 yr Author Anybody know how use this code in InnoSetup with a example...?Thanks and regards... ;-)I had rewriten the article, and provided an example in the attachment "pintaskbar.zip".
May 12, 201412 yr Author THIS IS AWESOME!!!Works like a charmThanks for your replyHope it can help you.
May 12, 201412 yr Already has, I added it to my AIDA64 installer and its working perfectly (even removes it on uninstall)
May 12, 201412 yr Author Already has, I added it to my AIDA64 installer and its working perfectly (even removes it on uninstall)remove the shortcuts form taskbar, I think it need to delete the shorcuts form the special directory.C:\Users\Current User\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar.(The directory is hide.)
May 12, 201412 yr Already has, I added it to my AIDA64 installer and its working perfectly (even removes it on uninstall)remove the shortcuts form taskbar, I think it need to delete the shorcuts form the special directory.C:\Users\Current User\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar.(The directory is hide.) Thanks again...!!!Regards... ;-) Already has, I added it to my AIDA64 installer and its working perfectly (even removes it on uninstall)How you delete the shortcut at uninstall...? deleting the shortcut in C:\Users\Current User\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar...?Regards... ;-) Edited May 12, 201412 yr by alfreire
May 12, 201412 yr Author Already has, I added it to my AIDA64 installer and its working perfectly (even removes it on uninstall)remove the shortcuts form taskbar, I think it need to delete the shorcuts form the special directory.C:\Users\Current User\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar.(The directory is hide.) Thanks again...!!!Regards... ;-) Already has, I added it to my AIDA64 installer and its working perfectly (even removes it on uninstall)How you delete shortcut at uninstall...? deleting the link...?Regards... ;-) Maybe U can see the [uninstallDelete] section in InnoSetup documentation.I am trying to find a way in section.but not finished.In theory, pin or unpin is the same way.
May 12, 201412 yr I don't have to do anything extra, for some reason mine is deleted automatically on uninstall (which is a nice thing)
May 12, 201412 yr I don't have to do anything extra, for some reason mine is deleted automatically on uninstall (which is a nice thing)Yes it's true, shortcut is delete during uninstall... only not delete when use Uninstallable=no in [setup]...Regards... ;-)
May 13, 201412 yr Author I don't have to do anything extra, for some reason mine is deleted automatically on uninstall (which is a nice thing) It is a good news!Regards... ;-)
May 13, 201412 yr Author I don't have to do anything extra, for some reason mine is deleted automatically on uninstall (which is a nice thing)Yes it's true, shortcut is delete during uninstall... only not delete when use Uninstallable=no in [setup]...Regards... ;-) It is helpful...Regards... ;-)
May 15, 201412 yr I'm no Inno expert. In fact, this is my first time using it. So I'm lost here. If I have an existing program installed on my PC and I want to create an installer that automatically pins it to the taskbar. I'm trying to figure out which code to modify in shuangxiang2008 included "PinShortcutOntoTaskbar-task.iss" script. Must I do something more than modify the paths to: (ExpandConstant('{app}') and the entry under [Files] Source: Thanks
May 15, 201412 yr I'm no Inno expert. In fact, this is my first time using it. So I'm lost here. If I have an existing program installed on my PC and I want to create an installer that automatically pins it to the taskbar. I'm trying to figure out which code to modify in shuangxiang2008 included "PinShortcutOntoTaskbar-task.iss" script. Must I do something more than modify the paths to: (ExpandConstant('{app}') and the entry under [Files] Source: ThanksHi... to help you better, what is the program, which you want make installer...?Regards... ;-)
May 16, 201412 yr Author I'm no Inno expert. In fact, this is my first time using it. So I'm lost here. If I have an existing program installed on my PC and I want to create an installer that automatically pins it to the taskbar. I'm trying to figure out which code to modify in shuangxiang2008 included "PinShortcutOntoTaskbar-task.iss" script. Must I do something more than modify the paths to: (ExpandConstant('{app}') and the entry under [Files] Source: ThanksI think your program is repacked by Inno.If you want to automatically pins it onto the taskbar, maybe you just need to modify the function CurPageChanged() ,you can remove IsTaskSelected()function,and remove the [task] section.like following:procedure CurPageChanged(CurPageID: Integer);begin //When Finished page is shown, call the function //You can also call is when the "Finish" button clicked. if CurPageID = wpFinished then begin //if IsTaskSelected('pintaskbar') then //if Selected the [task] zylPinAppToTaskbar(ExpandConstant('{app}'), 'MyProg.exe'); end;end;Hope can help you.Regards... ;-)
May 17, 201412 yr As an example, say I want to put a shortcut in the taskbar for magnify.exe, which is included with windows in the system32 folder. Since the program magnify.exe already exists, can I make an inno installer to install the taskbar shortcut pointing to magnify.exe since I now have to do this manually after a clean install? Edited May 17, 201412 yr by BYTE-ME
May 17, 201412 yr If I'm not mistaken:[Code]varPinTaskBarCheck : TNewCheckBox;//the function is work well on Unicode Inno Setup, //if Non Unicode Inno Setup, one need to modify,//and I think you can do it!//Inno use Win32 APIfunction LoadLibrary(lpFilename : String) : LongInt;external 'LoadLibraryW@kernel32.dll stdcall delayload'; //if Non Unicode Inno Setup, use LoadLibraryAfunction FreeLibrary(hModule : LongInt) : BOOL;external 'FreeLibrary@kernel32.dll stdcall delayload';function LoadString(hInstance:LongInt; uId:UINT; lpBuffer:String; nBufferMax:Integer) : Integer;external 'LoadStringW@user32.dll stdcall delayload'; //if Non Unicode Inno Setup, use LoadStringA//here is the function//@param strPath The App's directory,//@param strApp The App's name//@example zylPinAppToTaskbar('c:\window', 'notepad.exe');procedure zylPinAppToTaskbar(strPath, strApp: string); var vShell, vFolder, vFolderItem, vItemVerbs: Variant; vPath, vApp: Variant; i: Integer; sItem: String; h: LongInt; szPinName: String; filenameEnd : Integer; filename : String; strEnd : String;begin SetLength(szPinName, 255); h := LoadLibrary(ExpandConstant('{sys}\Shell32.dll')); LoadString(h, 5386, szPinName, 255); FreeLibrary(h); strEnd := #0; filenameEnd := Pos(strEnd, szPinName); filename := Copy(szPinName, 1, filenameEnd - 1); if (Length(filename) > 0) then //WinXp or lower, no pin taskbar function begin vShell := CreateOleObject('Shell.Application'); vPath := strPath; vFolder := vShell.NameSpace(vPath); vApp := strApp; vFolderItem := vFolder.ParseName(vApp); vItemVerbs := vFolderItem.Verbs; for i := 1 to vItemVerbs.Count do begin sItem := vItemVerbs.Item(i).Name; if (sItem = filename) then begin // 63 63 72 75 6E 2E 63 6F 6D vItemVerbs.Item(i).DoIt; break; end; end; end;end; //You can use zylPinAppToTaskbar like thisprocedure CurPageChanged(CurPageID: Integer);begin //When Finished page is shown, call the function //You can also call is when the "Finish" button clicked. if CurPageID = wpFinished then begin if IsTaskSelected('pintaskbar') then zylPinAppToTaskbar(ExpandConstant('{sys}'), 'magnify.exe'); end;end;zylPinAppToTaskbar(ExpandConstant('{sys}'), 'magnify.exe'); Regards... ;-) Edited May 17, 201412 yr by alfreire
May 19, 201412 yr Author As an example, say I want to put a shortcut in the taskbar for magnify.exe, which is included with windows in the system32 folder. Since the program magnify.exe already exists, can I make an inno installer to install the taskbar shortcut pointing to magnify.exe since I now have to do this manually after a clean install?use the function zylPinAppToTaskbar(), you just need two parameter,first, the dirctory of the *.exe;second, the real name of *.exe.maybe you must sure that *.exe is exist.then call the function where you need.
September 28, 201411 yr Slightly improved code... Change this:function LoadLibrary(lpFilename : String) : LongInt;external 'LoadLibraryW@kernel32.dll stdcall delayload'; //if Non Unicode Inno Setup, use LoadLibraryAfunction FreeLibrary(hModule : LongInt) : BOOL;external 'FreeLibrary@kernel32.dll stdcall delayload';function LoadString(hInstance:LongInt; uId:UINT; lpBuffer:String; nBufferMax:Integer) : Integer;external 'LoadStringW@user32.dll stdcall delayload'; //if Non Unicode Inno Setup, use LoadStringAto this:#ifdef UNICODE #define A "W"#else #define A "A"#endiffunction LoadLibrary(lpFilename : String) : LongInt;external 'LoadLibrary{#A}@kernel32.dll stdcall delayload'; function FreeLibrary(hModule : LongInt) : BOOL;external 'FreeLibrary@kernel32.dll stdcall delayload';function LoadString(hInstance:LongInt; uId:UINT; lpBuffer:String; nBufferMax:Integer) : Integer;external 'LoadString{#A}@user32.dll stdcall delayload'; to automatic Unicode/No Unicode library selection... not my code, I found searching in internet... (I don't know programming... X-D) Regards... ;-) Edited September 20, 201510 yr by alfreire
October 28, 201411 yr Author It is a very good change.Regards... ;-) Slightly improved code... Change this:function LoadLibrary(lpFilename : String) : LongInt;external 'LoadLibraryW@kernel32.dll stdcall delayload'; //if Non Unicode Inno Setup, use LoadLibraryAfunction FreeLibrary(hModule : LongInt) : BOOL;external 'FreeLibrary@kernel32.dll stdcall delayload';function LoadString(hInstance:LongInt; uId:UINT; lpBuffer:String; nBufferMax:Integer) : Integer;external 'LoadStringW@user32.dll stdcall delayload'; //if Non Unicode Inno Setup, use LoadStringAto this:#ifdef UNICODE #define A "W"#else #define A "A"#endiffunction LoadLibrary(lpFilename : String) : LongInt;external 'LoadLibrary{#A}@kernel32.dll stdcall delayload'; function FreeLibrary(hModule : LongInt) : BOOL;external 'FreeLibrary@kernel32.dll stdcall delayload';function LoadString(hInstance:LongInt; uId:UINT; lpBuffer:String; nBufferMax:Integer) : Integer;external 'LoadString{#A}@user32.dll stdcall delayload'; to automatic Unicode/No Unicode library selection... not my code, I found searching in internet... (I don'tt know programming... X-D) Regards... ;-)
March 4, 20224 yr OK Work KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK http://forum.oszone.net/post-2834519-92.html
