[AddOn] Restorator 2007 v3.70.1729
Restorator 2007 v3.70.1729 by bome.com
WARNING: This Program is NOT! FREE
Otional: But you CAN edit the addon's INF file to add your personal Name & Serial (a.k.a. Password)
Info: Resource Editor for Windows. Change, add, remove resources such as text, images, icons, sounds, videos, version, dialogs and menus in almost all programs.
MD5: 0C2F56728D3C029BBF34A99CD8B06722
Website: http://www.bome.com/Restorator/
Editing the INF file:
- Extract AddOn to a sub-directory
- Open Restratr.inf in Notepad. (recommend Notepad2 or Notepad++)
- Remove the 3 Semicolons from in front of the reg lines under the [Restorator.License] INF section
- Edit Name then Serial or Password with your personal ones
- Repack the AddOn as was and Integrate it
If you have any trouble editing the addon reply here or send me a PM and I will see what I can do.
So So much...
- Vista Icons support
- Drag and drop icons/resources
- You can copy and paste icons/resources "To & From" explorer
- You can record the changes you make to a certain resource. Just edit any DLL or EXE then hit the RP button and it will create a EXE Independent Patcher that you can re-apply the same resources/changes you did to the same file in the future.
- And much much more
  • 7 months later...
