[Addon] Total Uninstall 4.62
INFO: Total Uninstall - powerful installation monitor and advanced uninstaller.
Alternative uninstaller to Windows Add Remove Programs to remove programs completely.
With Installed Applications module analyze installed programs and create a log that can be used to do a complete uninstall even without the help of provided Add/Remove program.
With Monitored Applications module it helps to monitor any changes made to your system during the installation of a new application. It allows you to perform a complete uninstall without having to rely on the supplied Add/Remove program which can leave files or changes behind.
Website: http://www.martau.com/
MIRROR
MD5 - 6649D1CDC7B27B9F389A9A016C0FFDFF
Size - 2.24 MB
Edited by LUZR4LIFE
could somebody please put this file on a mirror ?
Also,is there a way to unattendedly register this program (provided that I have my registration code) ?
Thanks in advance!
Thanks in advance!
Added a mirror.
