Posted June 26, 200817 yr [Addon] Free Screen Recorder 2.9Free Screen Recorder is an easy-to-use screen recording program to capture screen activities and sounds to standard AVI video file. If you move the cursor, launch a program, type some text, click buttons, select some menus - anything you see on the screen - Free Screen Recorder will record all these, and sound from your system microphone.You can choose the output AVI file's video codec, framerate, audio codec, frequency; You can choose the cursor's display, to be actual cursor or custom one as you like, and you can add highlight to it. Record any part of the screen or even the entire desktop, with just a few clicks, or custom hotkeys.Free Screen Recorder is an ideal tool to make software demonstrations, develop videos for training and tutoring. Have fun with it!Key FeaturesRecords anything you see on your screen.Records sound from your microphone.Supports hotkey to start, pause, stop recording.Capture any part of the screen, even the entire desktop.Choose output video codec, framerate, audio codec, frequency.Mouse cursor recording can be turned on or off, true shape of the cursor is recorded. Show flashing rectangle when screen recording.Easy to use and user-friendly interface.MD5:FD142AC22A9FCBBDA8CAC05F5F1D39D5Size:482kbDownloadWebsite
July 13, 200817 yr Thanks. I removed the program shortcut from taskbar. I try to keep it as minimum as possible to allow more space for running programs.Initially I thought of trying Camtasia but this came along, so I got it installed & tried out. It is very easy to use. I'm keeping this addon
August 5, 200915 yr yes you can find my addon in complete addon list CamStudio Edited August 5, 200915 yr by mona
